Has probado a hacer un ajuste basico?
Enviado desde mi C6603 mediante Tapatalk
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000009
Shop #: WSC 06403 785 00200
1 Fault Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation
esta bien codificado y por mas que borro el fallo sale enseguida
Última edición por kekomovil; 19/04/2014 a las 12:49 Razón: problema resuelto
kekomovil (19/04/2014)
+1 : basic setting! !
solucionado
Basic Setting
Headlight Adjustment
[Select]
[55 - Xenon Range]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
- The meas. block field now shows "Wait" and should switch to "Adjust Headlights" then (this may take up to 10 seconds).
- Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target.
[ON/OFF/Next]
The adjustment should now be learned.
[Done, Go Back]
[Close Controller, Go Back - 06]
