Toma, aqui tienes la codificacion del modulo 46 con la subida con un toque activada:
1880200002407F3F85054C8FC677
Buenas, se ha comprado un amigo mio un s3. Y no tiene activada la funcion de apertura de ventanas con el mando, ni cierre. Os paso un auto-scan de todo el coche. Haber si alguno puede echar una mano.
VCDS Version: Release 805.0
Data version: 20080625
Tuesday,17,March,2009,13:57:47:43663
Chassis Type: 1K0
Scan: 01 03 04 08 09 10 14 15 16 17 19 22 25 37 42 44 46 52 55 56
62 72 77
VIN: WAUZZZ8Pxxxxxxxxx Mileage: 90km/55miles
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
22-AWD -- Status: OK 0000
37-Navigation -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CDL) Labels: None
Part No SW: 8P0 907 115 AB HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0H5FN600U
Coding: 0103000C180F0160
Shop #: WSC 06314 000 00000
No fault code found.
Readiness: 0000 0001
Address 03: ABS Brakes (-----) Labels: None
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 14428012092200FD281401E8902100413C00
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH08 0100
Revision: 000415 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008538584
Coding: F58E1F8190141380EF00000A0000000000084E056406040364 2000000000
Shop #: WSC 06314 000 08192
Part No: 8P1 955 119 F
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Part No: 8K0 910 557
Component: REGENLICHTSENSORH04 0003
Coding: 00150573
Shop #: WSC 06314
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 8P0 919 475 D HW: 8P0 919 475 A
Component: PARKHILFE 8K H06 0102
Revision: 11001001 Serial number: 84630815900938
Coding: 00000A
Address 14: Susp. Elect. Labels: None
Part No SW: 8P0 907 376 HW: 8P0 907 376
Component: J250 Raddaempfung 0030
Revision: --H03--- Serial number: 190DPH 8121129
Coding: 0000132
Address 15: Airbags (J234) Labels: None
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030354A55304C38503053
No ASAM data available for this controller: EV_Airba10AURB4 .
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.lbl
Part No SW: 8P0 920 932 HW: 8P0 920 932
Component: KOMBIINSTR. VDO H15 0820
Revision: D0H15004 Serial number: 2245H004000206
Coding: 0069128
Shop #: WSC 04450 572 90359
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0860205E7
Coding: E9AB7F064006022102
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H15004 Serial number: AUX7Z0H5FN600U
Address 37: Navigation Labels: None
Part No SW: 8P0 035 192 S HW: 8P0 035 192 S
Component: RNS-E HIGH EU H77 0650
Revision: 04S Serial number: AUZBZ7H4106950
Coding: 0209757
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000220
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.150 H08 1901
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1880200002186D0985054C8FC677
Shop #: WSC 04450 572 61726
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
2 Faults Found:
00955 - Key 1
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00956 - Key 2
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000220
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Revision: 00000001 Serial number:
Coding: 0000014
Address 56: Radio Labels: None
Coding: 0209757
Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000216
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000216
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 N HW: 8P0 862 335 N
Component: FSE_256x BT H34 0520
Revision: 00000000 Serial number: 00000005008783
Coding: 0011455
GOLF V _ GT SPORT - 1.9 105 cv ** + REPRO**
Parktronic 3C OEM + DEL y TRAS con visualizacion en RNS510. BLUETOOTH PREMIUM.
LUCES PUERTAS, HOMELINK, LUCES INTERIOR ASIENTOS TRASEROS, ILUMINACION MALETERO.
APERTURA DE PORTON DESDE PUERTA CONDUCTOR.
CLIMATRONIC CON CALEFACCION DE ASIENTOS.
Gracias amigo, estube ayer por la noche liado, y en el cuadro puedo modificar parametros como en todos. active el coming home y lo de las ventanas pero no funcionaba.
Probare con tu codificacion, gracias.
Madre mía que de canales tiene eso !!
En esta web puedes encontrar las codificaciones de todos los modulos y modelos de demas usuarios
Octavia 2 TDI 140CV BKD: Centralita 30b,Tempomat,Boton Clima, DRL Antiniebla 40%; Luces Americanas,Luces de Giro,5 Luces Freno,2ª Luz Antiniebla ,Navegador Colombus,Confort-Leaving Home,Junta EGR 9mm,Cuadro Maxidot RS,Faros Lupa Scout, Llantas 16", Polar FIS + Advance 350.000 km
Si, pero eso yo lo usaria para ver configuraciones de serie, no para meter una a mi coche, ya que cada configuracion es para cada coche, pueden coincidir muchas cosas, pero que coincidan todas es casi imposible, por lo que meter una codificacion de otro coche sin saber que lleva ni que tiene activado, no lo veo normal.
Lo suyo es coger la original del coche y con el vag-com modificarla.
Salu2
He metido la codificacion y no funciona, que cosa mas rara.
Ahora mismo la que tiene es la siguiente.
1880200002C07F3F8F0F4C8FC677
funciona el coming home, el leaving home. el pitido de la alarma en apertura y cierre. Y la alimentacion de puerta hasta apertura, pero yo creo que no funciona el cierre de ventanilla, porque nada mas abrir puerta corta alimentacion. Pero aun haciendolo de dento tampoco funciona.
