eso tampoco ya lo hice y nada de nada el vag con dice esto
VAG-COM Version: Release 311.2-N
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 038 906 013 AB
Component: 1,9l R4 EDC 0000SG 2164
Coding: 00002
Shop #: WSC 06403
1 Fault Found:
00741 - Brake Pedal Monitoring
27-00 - Implausible Signal
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Coding: 06406
Shop #: WSC 11111
No fault code found.
Address 08 -------------------------------------------------------
Controller: 6K0 959 291
Component: AUTOCLIMA-220 X06.00
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6K0 920 801 E
Component: 6K-KOMBIINSTR. VDO V02
Coding: 00143
Shop #: WSC 00000
IMMO-IDENTNR: SEZ7Z0B1499483
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
End ------------------------------------------------------
Última edición por DOMINGO69; 05/09/2014 a las 19:25
