Deje de acelerar un momento de ahí esas caídas
una ayudita con estos errores a los entendidos
gracias
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 038 906 019 NE
Component: 1,9l R4 EDC 0000SG 6119
Coding: 00102
Shop #: WSC 06402
SEZ7Z0D2584180
No fault code found.
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 R
Component: ABS 8.0 front H03 0001
Coding: 0000008
Shop #: WSC 06403
Address 08 -------------------------------------------------------
Controller: 6L0 820 045
Component: Klimaanlage X0840
2 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
41-00 - Blocked or No Voltage
00819 - High Pressure Sensor (G65)
07-00 - Signal to Low
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00012
Shop #: WSC 06402
1 Fault Found:
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 801 A
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 00144
Shop #: WSC 00000
SEZ7Z0D2584180
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 0061 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
1 Fault Found:
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AA
Component: LenkhilfeKYO V957
Coding: 10111
Shop #: WSC 06402
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 0M Komfortgerát 0002
Coding: 00066
Shop #: WSC 06402
2 Faults Found:
00931 - Locking Module for Central Locking: Rear Right (F223)
27-10 - Implausible Signal - Intermittent
End -------------------------------------------------------
Última edición por pedoreto; 01/11/2014 a las 02:56
Esas averías has probado a borrarlas? o están sin borrar? si no están borradas ya sabes que deberías hacer, puesto que no se sabe si son reales o sucedieron en el pasado y ya están subsanadas y solo pendientes de borrarse. Con respecto al LOG de turbo y caudalimetro, veo todo bien.
El turbo cargo bastante bien, el caudalimetro mide lo correcto para un ATD, la EGR trabaja correcta, y la N75 y el turbo trabajan bien y se les ve con salud (a pesar de que levantaras el pie) se a podido leer bien el LOG. Seguro que el coche va bien, y no debes de tener pega. Salu2
Lo que si note es que perdió un poco de patada. Desde que lo compre, o puede ser que me acostumbre a el. respecto los errores son fijos ,los borre y otra ves salen .
01596 trampilla de recirculacion de aire atascada o sin tension, esto es la recirculacion de aire del climatizador
00819 sensor de presion del refrigerante, señal muy baja. Seguramente tengas descargado el aire acondicionado
01336 bus de datos del sistema confort, esta trabajando solo con una linea. Comprobar cableado y resistencias terminales de la linea CAN. Este lo tienes repetido en varios modulos
00931 modulo de puerta trasero derecho, señal implausible. Quizas has intentado cerrar el coche con la puerta abierta o algo por el estilo o no detecte la puerta cerrada.... Este fallo no esta presente, solo guardado
Haz como te dice codi, borralos y vuelve a leer
Si,ya lo hice son errores después de haber borrado ,este verano recargue el aire y duro 1 dia .tendrá alguna fuga .
