Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ7P012680 Mileage: 171010km/106260miles
15-Airbags -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 J HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0030
Revision: 5BH15--- Serial number: VWZ7Z0F8135656
Coding: 0403000318070060
Shop #: WSC 00191 264 15243
VCID: 2D51EF3FB4E4E5760F5-8078
1 Fault Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
Shop #: WSC 00028 028 00001
VCID: 73E539471240F386991-8026
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BH HW: 1K0 907 044 BH
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6ED328337962DE6E76F-803B
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004440665
Coding: ED8D0F2700041500001400001400000000197F075C
VCID: 2B55E1278AF0EB46111-807E
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 290906 020 0501
Coding: 00038805
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 250906 014 1201
Coding: 00208933
Shop #: WSC 00028
2 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 212
Mileage: 171015 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 212
Mileage: 171015 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0T2L7M
Coding: 0013111
VCID: 3D71DF7F648475F6BF5-8068
Subsystem 1 - Serial number: 6332MSME1212586EA
Subsystem 2 - Serial number: 6342MSME12053A2E9
Subsystem 3 - Serial number: 6352QSME11144305$
Subsystem 4 - Serial number: 6362QSME125B2D3DS
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000012
VCID: 74E73A5B174EF4BE80B-8021
Part No SW: 1K6 920 863 HW: 1K6 920 863
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F8135656
Coding: 0001103
Shop #: WSC 00011 888 96745
VCID: EED3A833F9625E6EF6F-80BB
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001069188508
Coding: 3D3F034007000002
VCID: 2C57E23B8FFEEC7E18B-8079
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 212
Mileage: 171015 km
Time Indication: 0
Date: 2000.00.00
Time: 00:15:20
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 212
Mileage: 171015 km
Time Indication: 0
Date: 2000.00.00
Time: 00:15:25
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 005 0971
Coding: 0000182
VCID: 3979CB6F70AC49D693D-806C
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
VCID: 3467FA5B57CEB4BE40B-8061
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 019002005103087F2D04840D7008CFC6F0FCA0
VCID: 8305E987C2E04306091-80D6
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Component: IRUE No Answer
3 Faults Found:
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 212
Mileage: 171015 km
Time Indication: 0
Date: 2000.00.00
Time: 00:17:32
00323 - Vehicle Inclination Sensor (G384)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 212
Mileage: 171015 km
Time Indication: 0
Date: 2000.00.00
Time: 00:17:32
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 212
Mileage: 171015 km
Time Indication: 0
Date: 2000.00.00
Time: 00:17:32
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000438
VCID: 3A7BD46375AA42CE9A7-806F
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 005 0913
Coding: 0000144
Shop #: WSC 00028 028 1012545
VCID: 387FCE6B4BA650DE6C3-806D
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
