Muy buenas,
Os subo la lectura del vag a ver que opinais
Código:
Tuesday,27,December,2016,22:36:35:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVGZZZ1TZ6W201303 License Plate:
Mileage: 191210km-118812mi Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 52 55 56 62 72 76
77
VIN: WVGZZZ1TZ6W201303 Mileage: 191210km/118812miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DB HW: 03G 906 018 J
Component: R4 2.0l PPD1.2 G 4344
Revision: --H22--- Serial number: VWZ7Z0F4149628
Coding: 0000072
Shop #: WSC 46931 133 91987
VCID: 68DF5E2B5B86005E3C3-803D
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023238
Shop #: WSC 01324 785 00200
VCID: 73E539471240F386991-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 70EF364B6356C89E643-8025
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005911107
Coding: FB8B8F2100040F0000120C000000000000197F0746
VCID: 2B55E1278AF0EB46111-807E
Subsystem 1 - Part No: 1T0 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 130606 020 0501
Coding: 00038805
Shop #: WSC 01324
Subsystem 2 - Part No: 1K0 955 559 AD Labels: 1K0-955-559-AF.CLB
Component: RLS 150506 014 1201
Coding: 06500389
Shop #: WSC 01324
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0K6AA
Coding: 0012338
VCID: 3561C75F5CB4ADB6775-8060
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
Component: J0527 636 0070
Coding: 0002022
VCID: 75E1075F1C34EDB6B75-8020
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Part No: 1T0 920 872 F
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0007101
Shop #: WSC 58744 002 1048576
VCID: 377DCD5746B85FA6659-8062
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 R
Component: Zuheizer 050 2302
Revision: 00050000 Serial number: 09009839000000
Coding: 0000011
VCID: 3467FA5B57CEB4BE40B-8061
2 Faults Found:
01489 - Over-Temp Sensor (G189)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 119
Mileage: 162923 km
Time Indication: 0
Freeze Frame:
Start
Temperature: 24.0°C
Temperature: 34.0°C
Voltage: 13.44 V
02251 - Heater Unit Locked
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 119
Mileage: 162923 km
Time Indication: 0
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001066090198
Coding: 7D3F17C807008002
VCID: 2C57E23B8FFEEC7E18B-8079
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 4312
Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
Part No: 1K0 919 887 F
Component: Navigation 0030
Coding: 0000101
VCID: 3C77D27B7F9E7CFE88B-8069
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1T0 959 701 C
Component: Tuer-SG 024 2821
Coding: 0000249
1 Fault Found:
00100 - Drivers Interior Locking Button (E308)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.071 H07 1806
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CB HW: 1K0 959 433 CB
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 189002085103487F2D060E0F90084F01E0BD00
VCID: 72EB3C436D5AFA8E927-8027
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1T0 959 702 C
Coding: 0000245
VCID: 387FCE6B4BA650DE6C3-806D
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000001
VCID: F4E7BA5B974E74BE00B-80A1
Address 56: Radio Labels: 1K0-035-095.lbl
Part No: 1K0 035 095 E
Component: Radio 0030
Coding: 0042402
VCID: 275D1D179618CF26F59-8072
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2428
Coding: 0000144
VCID: 326BFC43ADDABA8E527-8067
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
VCID: 3365F94752C0B386591-8066
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 02 Einparkhilfe 0101
VCID: 2D51EF3FB4E4E5760F5-8078
Address 77: Telephone Labels: 1K0-035-729-UNI.lbl
Part No: 1K0 035 729 E
Component: CIB PAH HW 203 SW 0308
Coding: 0000214
