Piloto Airbag encendido en VW UP
Hola a todos!
en el VW Up de mi mujer hace un tiempo que se enciende la luz de averia airbag, le paso el soft y reseteo alarmas pero en pocas horas vuelve a salir.
Aquí dejo el diagnósitco a ver si alguien me puede echar una mano, muchas gracias.
Tuesday,02,May,2017,20:27:22:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
VIN: WVWZZZAAZCD006051 License Plate:
Mileage: 40530km-25184mi Repair Order:
Chassis Type: AA (6N0)
Scan: 01 03 09 13 15 17 19 25 44 56 AD
VIN: WVWZZZAAZCD006051 Mileage: 40530km-25184miles
01-Engine -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
AD-Brake Sensors -- Status: Malfunction 0010
Address 01: Engine (------CHYB) Labels: 04C-906-020-CHY.clb
Part No SW: 04C 906 020 A HW: 04C 907 309
Component: 1.0l R3 MPI H01 2423
Revision: U7H01--- Serial number:
Coding: 00110012020400000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM10MPI01104C906020A 001010
ROD: EV_ECM10MPI01104C906020.rod
VCID: 193E16261802F2890E-804C
1 Fault Found:
5649 - Throttle Control
P3078 00 [101] - Airflow at Idle too Low
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 40471 km
Date: 2017.04.29
Time: 18:15:30
Engine speed: 3014.00 /min
Normed load value: 13.7 %
Vehicle speed: 81 km/h
Coolant temperature: 87 °C
Intake air temperature: 33 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.418 V
Unlearning counter according OBD: 40
Fuel level: 35.00 l
Readiness: 0000 0100
Address 03: ABS Brakes (J104) Labels: 1S0-614-517.clb
Part No SW: 1S0 614 517 C HW: 1S0 614 517 C
Component: EBC 460 ESP H08 0004
Serial number: 0021868
Coding: 12BF247189AD02F748FA24FA91AA404058B000
ASAM Dataset: EV_Brake1UDSESP 015024
ROD: EV_Brake1UDSESP.rod
VCID: 2F6AC8FE76860C3940-807A
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 1S0-937-08x-09.clb
Part No SW: 1S0 937 086 HW: 1S0 937 086
Component: PQ25 BCM H57 0511
Revision: -0------ Serial number: 1009068800
Coding: 24B0290000010000000000042C282CD00040400C6002000020 0000420100
VCID: 75E63A96DC5A76E9CA-8020
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 7
Reset counter: 239
Mileage: 40490 km
Time Indication: 0
Date: 2017.05.01
Time: 12:03:24
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 1S0 959 655 HW: 1S0 959 655
Component: VW10Airbag005 H02 0005
Revision: -------- Serial number: 003G3000BVK+
Coding: 000000000000000000000000000000003035
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 7BF22CAEF27E2099BC-802E
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40590SM2O5OA-
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB404P0SM2O40AR
Crash sensor for front airbag: driver side:
Serial number: 3555NRB405V0TO4MB0PJ
1 Fault Found:
9445417 - Key switch for deactivation of passenger-side airbag
B1020 29 [136] - Signal Implausible
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 40419 km
Date: 2017.04.29
Time: 08:11:38
Address 17: Instruments (J285) Labels: 1Sx-920-xxx-17.clb
Part No SW: 1S0 920 860 B HW: 1S0 920 860 B
Component: KOMBI H08 0019
Revision: X0008003 Serial number: 00000000000000
Coding: 114200
ASAM Dataset: EV_KombiUDSMM9RM10 A04708
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 1S0 937 086
Component: GW-K-CAN TP20 H57 0511
Revision: -0------
Coding: 001000
Shop #: WSC 78129 152 411206
VCID: 70E80B82A33853C119-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 1S0 920 860 B
Component: IMMO H08 0019
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW01.rod
VCID: 6ADC19EA8DE4A91157-803E
Address 44: Steering Assist (J792) Labels: 1Sx-909-144-44.clb
Part No SW: 1S1 909 144 F HW: 1S1 909 144
Component: EPS_ECU H15 1502
Coding: 0001000101000000
ASAM Dataset: EV_SteerAssisNSK 008004
ROD: EV_SteerAssisNSK_006.rod
VCID: 3664FD9A89DC3DF103-8062
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1S0 035 156 A HW: 1S0 035 156 A
Component: Radio H35 0045
Revision: R0000000 Serial number: VWASASL2702653
Coding: 0000020801
VCID: 295E26E6406262099E-807C
Address AD: Brake Sensors (J939) Labels: 1S0-907-201.clb
Part No SW: 1S0 907 201 HW: 1S0 907 201
Component: CV-SENSOR H05 0450
ASAM Dataset: EV_CVSen 001001
ROD: EV_CVSen.rod
VCID: 67DA60DE9EF6947948-8032
1 Fault Found:
0004 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 31
Reset counter: 239
Mileage: 40293 km
Date: 2017.04.24
Time: 06:59:53
End-------------------------(Elapsed Time: 01:48)--------------------------
B102029 - Conm. de llave p. desactiv. del airbag del lado acomp. ,Señal no plausible
Te toca revisar la cerradura de desactivación del Airbag.
OK, mucha gracias ! voy a ver si veo algo.... moveré la cerradura activando/desactivando el airbag y a ver si hay suerte y si no seguiré los cables...etc.. supongo que es un contacto abierto o cerrado. Muchas gracias!
Hola, ya solucionaste lo del airbag ?¿, yo tengo un Mii con el mismo error. Gracias.
En mi Jetta un tiempo se me encendía el testigo del airbag y era por qué al jalar asiento todo hacia atrás se estira el arnes ... Espero te sirva de algo saludos
Es un tema ya un poco viejo pero os comento que al final lo llevé al taller y era un interruptor, me lo cambiaron y listos.
El Siguiente Usuario Agradeció a trooper Por Este Mensaje:
