Resultados 11 al 20 de 23
Tema: No puedo comprobar turbo geometria variable - vag 01 engine 04- basics settings - 11
    Entiendo, que estás 2 averías del principio, salen cuando se enciende el testigo de avería, que luego borras averías y sigues usando el coche tras salir del taller:
    Address 01: Engine Labels: 03L-906-023-CAY.clb
    Control Module Part Number: 03L 906 023 LG HW: 03L 906 023 KL
    Component and/or Version: 1,6l R4 CR td H43 8832
    Software Coding: 00114016032401080000
    Work Shop Code: WSC 06402 785 00200
    ASAM Dataset: EV_ECM16TDI02013L906023LG 003005 (VW36 *)
    ROD: N/A
    VCID: 76E43D9AC95C7DF1C3-8022
    No ASAM data for: "EV_ECM16TDI02013L906023LG" (VW36 *)
    2 Faults Found:
    7286 - ROD - Unknown Error Code
    - 00 [032]
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 90995 km
    Date: 2017.11.14
    Time: 11:41:58
    9854 - ROD - Unknown Error Code
    - 00 [175]
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 91080 km
    Date: 2000.00.00
    Time: 00:00:00
    y estás, supongo que tras borrar averías ese día, han salido de nuevo:
    Readiness: 0100 0000
    070 VA0 570901076
    Despues:
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    61-Battery Regul. -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 LG HW: 03L 906 023 KL
    Component: 1,6l R4 CR td H43 8832
    Revision: --H43--- Serial number:
    Shop #: WSC 06402 785 00200
    ASAM Dataset: EV_ECM16TDI20103L906023LG 003005
    ROD: N/A
    No ASAM data for: "EV_ECM16TDI20103L906023LG" (VW36 *)
    2 Faults Found:
    - 00 [032]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 90995 km
    Date: 2017.11.14
    Time: 11:41:58
    - 00 [237]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 91080 km
    Date: 2000.00.00
    Time: 00:00:00
    Si estoy en lo cierto, se ha vuelto a registrar de nuevo tras pasar por el taller, está avería:
    - 7286 - Turbocharger Boost Control Position Sensor Circuit - Implausible Signal.
    Y se registra esta nueva, que no salía antes y te pongo lo que es y cómo solucionarla:
    VAG Error Code: 13812/9854
    EOBD II Error Code: P246F
    Fault Location:
    Exhaust Gas Temperature (EGT) Sólo usuarios registrados pueden ver links. Por favor, regístrate en el foro haciendo click AQUI. (G648), Bank 1 - Circuit Range/Performance Problem/Implausible Signal
    Possible Cause:
    Wiring/Connector(s).
    Exhaust Gas Temperature (EGT) Sensor 4 (G648), Bank 1.
    Engine Control Module (ECM).
    Possible Solutions:
    Check/Replace all faulty Wiring/Connector(s).
    Read Measuring Value Blocks (MVB).
    Check/Replace Sólo usuarios registrados pueden ver links. Por favor, regístrate en el foro haciendo click AQUI. Gas Temperature (EGT) Sólo usuarios registrados pueden ver links. Por favor, regístrate en el foro haciendo click AQUI. (G648), Bank 1.
    Tú al recoger el coche no borraste averías?? se quedaron todas borradas en el módulo de motor? porque intento saber si se han registrado de nuevo o no para saber si son reales de verdad o no. Pusiste la misma batería que llevabas? mismo amperaje, marca y potencia de arranque??
    Nº de Usuario: 69774
    01-nov-2017
    valencia
    SEAT ALTEA XL 1.6 TDI
    Hola de nuevo codi31!
    Cuando salió el coche del taller no marcaba error en el cuadro. Yo le pase el scan a raíz de la luz del motor.
    Pero ahora que lo dices, no se si los dos logs son sin haber borrado los fallos... vaya cabeza!
    Hoy se me ha vuelto a encender, si antes lo digo... volveré a hacer una pasada con el vcds y resetear y cuelgo los 2.
    Lo de la batería, en el taller me montaron una que no era amg y después yo monté la varta que tocaba y le devolví la normal.
    Gracias por la ayuda e informacion que me has puesto. En cuanto llegue a casa lo veo.
    Un saludo!
  3. #13
    Haz un AutoScan, y al acabar, lo guardas. Borras averías, y usa el coche tranquilamente el fin de semana. El domingo o el lunes, nuevo AutoScan y pones ambos aquí. Hazlo tal cual te he dicho de hacerlo, porque así sabremos qué averías son reales y podemos seguir con la ayuda.
    P.D: Identifica bien qué AutoScan es el borrado y sin borrar.
  4. El Siguiente Usuario Agradeció a codi31 Por Este Mensaje:
    ruba87 (27/12/2017)
  5. #14
    01-nov-2017
    valencia
    Buenas tardes y felices fiestas a los que estáis por aquí.
    Vengo con una nueva entrega de mis problemas... Codi, hice en su día lo que me dijiste del log después de borrar fallos y el nuevo log con los fallos (ese es de ayer aunque el fallo me salio enseguida). Otra cosa que me trae mosca es el error en el modulo de la batería, ¿quizás por eso no funciona el start-stop?
    Pues allá voy:
    Sin error
    Chassis Type: 5P (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 61 77
    VIN: VSSZZZ5PZBR036161 Mileage: 91220km-56681miles
    01-Engine -- Status: OK 0000
    ASAM Dataset: EV_ECM1T6DI02103L906023LG 003005
    ROD: N/A
    No ASAM data for: "EV_ECM1T6DI02103L906023LG" (VW36 *)
    No fault code found.
    Readiness: 0110 1000
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
    Component: ESP MK60EC1 H31 0108
    Revision: 00H31001
    Coding: 213F401209250000840C02EA901A0051350000
    Shop #: WSC 04941 000 00000
    VCID: 76E43D9AC15C7DF1C3-8022
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 5P0 907 044 P HW: 5P0 907 044 P
    Component: Climatronic H15 0702
    Revision: 00001001
    Coding: 0000000003
    ASAM Dataset: EV_Cliamtronic A01006
    ROD: N/A
    VCID: 3D76E2B6ACEAEEA9C2-8068
    No ASAM data for: "EV_Cliamtronic" (VW36 *)
    Address 09: Cent. Elect.
    Cannot be reached
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: S7 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD2R8Y5$
    Coding: 0021303
    VCID: 3D76E2B664EAEEA9C2-8068
    Subsystem 1 - Serial number: 6332MSME5C22737DM
    Subsystem 2 - Serial number: 6342MSME5C6133079
    Subsystem 3 - Serial number: 6351HSME266E5B79R
    Subsystem 4 - Serial number: 6361HSME26545479A
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
    Component: LENKS.MODUL 014 0140
    Revision: FF010040 Serial number: 20110401300613
    Coding: 108A140002
    ASAM Dataset: EV_SMLSGNVOLWSXS A01004
    ROD: N/A
    VCID: 79FE36A6F8421289AE-802C
    Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAP H02 0102
    Coding: E20000
    No ASAM data for: "EV_SMLSGNVOLWSXS" (VW36 *)
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 1P0 920 853 C HW: 1P0 920 853 C
    Component: KOMBI H06 0420
    Serial number: 00000000000000
    Coding: 110B00
    Shop #: WSC 131071 1023 2097151
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
    ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
    VCID: 2F6AC8FE76860C3940-807A
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 D HW: 1K0 907 951
    Component: J533 Gateway H35 0614
    Revision: H35 Serial number: 190311F1001868
    Coding: 352202
    VCID: 316ECE8668B21AC956-8064
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H06 0420
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UD_SVDD_RM09 A03008
    ROD: N/A
    VCID: 6ADC19EA8DE4A91157-803E
    No ASAM data for: "EV_Immo_UD_SVDD_RM09" (VW36 *)
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 6J0 035 342 D HW: 6J0 035 342 D
    Component: SG EXT.PLAYER H13 0150
    Revision: A1001003 Serial number: 7669622649
    Coding: 010000
    Shop #: WSC 00048 781 84926
    VCID: 25462AD62C7A4669BA-8070
    1 Fault Found:
    03138 - Input AUX IN
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 91220 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 23:02:60
    Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 1T0 959 701 AK HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0505
    Revision: 13110009 Serial number: 0001840455
    Coding: 020030
    ASAM Dataset: EV_TSFGPQ35BRFVW46X A04001
    ROD: N/A
    VCID: 00085B429B984341E9-8054
    No ASAM data for: "EV_TSFGPQ35BRFVW46X" (SE35)
    1 Fault Found:
    66562 - ROD - Unknown Error Code
    - 00 [009]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 194
    Mileage: 91220 km
    Date: 2017.12.07
    Time: 22:15:21
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 65 3201
    Revision: 00H20000
    VCID: 3460C79257A02FE13D-8060
    Address 46: Central Conv.
    Cannot be reached
    Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 1T0 959 702 AF HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0505
    Revision: 15110009 Serial number: 0001847132
    Coding: 020030
    ASAM Dataset: EV_TSGBP3Q5BRFVW46X A04001
    ROD: N/A
    VCID: 7CF02FB2F77027A1B5-8028
    No ASAM data for: "EV_TSGBP3Q5BRFVW46X" (SE35)
    1 Fault Found:
    - 00 [009]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 91220 km
    Date: 2017.12.07
    Time: 22:15:21
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 5P0 035 186 HW: 5P0 035 186
    Component: Media2.0 H01 0007
    Revision: 01000001 Serial number: SEZ1Z3L0214791
    Coding: 0004040004
    VCID: 6CD01FF28F10B72125-8038
    1 Fault Found:
    00856 - Radio Antenna
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 91220 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 22:15:44
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H35 0614
    Coding: 0303185A
    VCID: 71EE0E86A8325AC916-8024
    1 Fault Found:
    00458 - Control Module for Battery Monitoring (J367)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 91220 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 22:16:22
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 5K0 035 730 HW: 5K0 035 730
    Component: TELEFON H09 1020
    Revision: 1B001001 Serial number: 00007669574513
    Coding: 0500000001010110
    ASAM Dataset: UHVNA A01009
    ROD: UHVNA.rod
    VCID: 62CC71CA75D4F1519F-8036
    End-------------------------(Elapsed Time: 02:35)--------------------------
    Con el error:
    VIN: VSSZZZ5PZBR036161 Mileage: 92500km-57476miles
    2E-Media Player 3 -- Status: Malfunction 0010
    77-Telephone -- Status: Malfunction 0010
    ASAM Dataset: EV_EC1M6TDI02103L906023LG 003005
    ROD: N/A
    No ASAM data for: "EV_EC1M6TDI02103L906023LG" (VW36 *)
    1 Fault Found:
    - 00 [237]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 91554 km
    Date: 2000.00.00
    Time: 00:00:00
    Revision: 00H31001
    Revision: 00001001
    Coding: 0000000003
    ASAM Dataset: EV_Climtaronic A01006
    ROD: N/A
    No ASAM data for: "EV_Climtaronic" (VW36 *)
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 086 J HW: 1K0 937 086 J
    Component: BCM PQ35 M+ 103 0615
    Revision: 00103 AE
    Coding: 46180A3C800508B04288008095008104426118A8425D81605C 80C7000041
    Shop #: WSC 04941 123 12345
    VCID: 377AF09E86D6C4F918-8062
    Subsystem 1 - Part No: 5P0 955 119 D Labels: 1KX-955-119.CLB
    Component: Wischer 21031 26 0611
    Coding: 00DB90
    1 Fault Found:
    02391 - Terminal 30 Reference
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 91220 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 22:15:22
    Freeze Frame:
    Term 15 On
    Voltage: 14.40 V
    ON
    ON
    Term 50 On
    OFF
    OFF
    Coding: 0021303
    Coding: 108A140002
    ASAM Dataset: EV_MSLSNGVOLWSXS A01004
    ROD: N/A
    Coding: E20000
    No ASAM data for: "EV_MSLSNGVOLWSXS" (VW36 *)
    Coding: 110B00
    Coding: 352202
    Serial number:
    Coding: 000000
    ASAM Dataset: EV_Imom_UDS_VDD_RM09 A03008
    ROD: N/A
    No ASAM data for: "EV_Imom_UDS_VDD_RM09" (VW36 *)
    Coding: 010000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 210
    Mileage: 91220 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 23:02:60
    Coding: 020030
    ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
    ROD: EV_TSGFPQ35BRFVW46X.rod
    2 Faults Found:
    66562 - Heated Exterior Mirror
    B11F8 14 [009] - Open or Short to Ground
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 206
    Mileage: 91220 km
    Date: 2017.12.07
    Time: 22:15:21
    67331 - Interior Switch for Central Locking
    B1230 29 [008] - Signal Implausible
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 246
    Mileage: 92254 km
    Date: 2017.12.22
    Time: 03:05:43
    Revision: 00H20000
    Coding: 020030
    ASAM Dataset: EV_TSGBPQ3B5RFVW46X A04001
    ROD: N/A
    No ASAM data for: "EV_TSGBPQ3B5RFVW46X" (SE35)
    1 Fault Found:
    - 00 [009]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 91220 km
    Date: 2017.12.07
    Time: 22:15:21
    Coding: 0004040004
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 91220 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 22:15:44
    Coding: 0303185A
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 91220 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 23:13:19
    Shop #: WSC 12345 123 12345
    ROD: UHVNA.rod
    1 Fault Found:
    9457427 - Left audio channel for speech/telephone
    B104F 13 [008] - Short to GND
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 234
    Mileage: 91220 km
    Date: 2017.12.07
    Time: 23:34:41
    End-------------------------(Elapsed Time: 02:41)--------------------------
    El error concreto:
    Wednesday,27,December,2017,00:24:55:39744
    VCDS Version: Release 17.1.3 Running on Windows 10 x64
    ASAM Dataset: EV_ECM16TDI02103L906023LG 003005 (SE35)
    ROD: EV_ECM16TDI02103L906023NR.rod
    1 Fault Found:
    9854 - Exhaust Gas Temperature Sensor 4 Bank 1
    P246F 00 [237] - Implausible Signal
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 91554 km
    Date: 2000.00.00
    Time: 00:00:00
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 14 °C
    Intake air temperature: 15 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 11.859 V
    Unlearning counter according OBD: 40
    Exhaust gas temperature sensor 1-TEG_MES[0]: 19.98 °C
    Exhaust gas temperature sensor 3-TEG_MES[1]: 12.91 °C
    Exhaust gas temperature sensor 4-TEG_MES[2]: 999.98 °C
    Sensor for temp after charge air cooler: raw value-TBA_MES: 14 °C
    Outside air temperature-Ambient temperature: 12.75 °C
    Shut-off timer: last ECM after-run time-T_ES_FCT_DIAG: 0.00 s
    Time since engine start: 0 s
    Un saludo!!
  6. #15
    Nº de Usuario: 13732
    27-abr-2012
    Asturias
    Seat Leon 2.0 tdi 140 cv bkd
    esto que pone no es correcto compruebalo otra vez
    estaba el coche en marcha o solo contacto?
  7. El Siguiente Usuario Agradeció a hera Por Este Mensaje:
    ruba87 (28/12/2017)
  8. #16
    01-nov-2017
    valencia
    Cita Iniciado por hera Ver Mensaje
    Hola hera!
    Pues eso es lo que me trae mosca. El coche estaba en marcha.
    Gracias y un saludo
  9. #17
    Pues según tu Vag-Com, el motor estaba parado:
    Engine speed: 0.00 /min (revoluciones a 0)
    Vehicle speed: 0 km/h (velocidad a 0)
    Voltage terminal 30: 11.859 V (voltaje de batería muy bajo)
    Exhaust gas temperature sensor 4-TEG_MES[2]: 999.98 °C (error del sensor 4)
    Time since engine start: 0 s (tiempo desde el arranque del motor = 0 seg)
    Seguramente esta avería se registró al poner el contacto, no con motor arrancado. Según esta avería, te falla el sensor 4 de temperatura del gas de escape, y las mediciones de dicho sensor así lo atestiguan. Sobre el tema de la batería, te dice que falla el módulo de control que gobierna la batería. Pusiste una batería original? igual a la anterior?? mismo amperaje y potencia de arranque? seguro que la codificaste bien??
    Última edición por codi31; 29/12/2017 a las 12:51
  10. El Siguiente Usuario Agradeció a codi31 Por Este Mensaje:
    ruba87 (28/12/2017)
  11. #18
    01-nov-2017
    valencia
    Hola de nuevo codi!
    Uy uy uy, que mal rollo da todo.
    La batería la puse nueva, del mismo amperaje y la codifique bien (se supone) Creo que está avería viene de lejos porque hace años que no va el start-stop ¿¿Puede ser que el borne este sulfatado??
    Las revoluciones del motor me dan mal rollo, pero juraría que estaba en marcha. Lo volveré a probar. O será del registro de la avería como dices.
    Entonces sólo me queda saber dónde está el sensor 4, revisarlo y cambiarlo ¿no?
    Gracias, saludos y felices fiestas
  12. #19
    Cita Iniciado por ruba87 Ver Mensaje
    Juraría que estaba en marcha.
    Se me olvido remarcar esto:
    Time since engine start: 0 seg (tiempo desde el arranque del motor = 0 seg)
    Aparece justo al final de la descripción de avería. Como te digo, el motor no estaba arrancado, seguramente fue al poner el contacto cuando te a marcado la avería del sensor 4. También llama la atención el voltaje de batería (11.85V) que para arrancar un motor, es muy baja carga.
    Yo, usaba un polímetro (y por si acaso) comprobaba esa batería. Dejaba el coche parado a poder ser un día entero, bajaba al mismo, abría la puerta del conductor y el capó, cerraba la puerta del conductor y medía la carga y lo apuntaba en un papel. Después, pedía a alguien que arrancase el motor, y tú mientras con el polímetro conectado en la batería, midiendo cuánto baja la carga al abrir la puerta, poner contacto (etc..) y justo cuánto baja la carga de batería en el proceso de arranque del motor, justo ahí.
    Es decir, en el momento justo que está girando el motor de arranque para arrancar el motor, sin que este llegue a arrancar. Apuntar todo y ponerlo aquí. Y por supuesto, ya de paso, sacaba y lijaba ese borne sulfatado, repasaba el otro, limpiaba bien todos los restos de sulfatado, y procuraba poner bien los bornes de batería y bien apretados, y borrar averías y ver si va el Start&Stop.
    Y ver si aparecen de nuevo las averías del módulo 09 y 061. Lo raro que avería del Start&Stop no aparece reflejada, pero seguro que se debe al problema del módulo 061. Por supuesto, te queda averiguar dónde va el sensor 4, y cambiarlo, porque si es avería real. Salu2
  13. #20
    01-nov-2017
    valencia
    Hola a todos de nuevo. Después de una temporada muy muy liado y desconectado, me he puesto con el Altea otra vez.
    La solución ha sido fácil, la pongo por si a alguien le pasa: Verificación de la sonda, limpieza y limpiaconectores y voila! Reseteo y despues de bastantes km ya no tengo fallo. Esta claro que era una mala conexión. Así que un problema menos, los demás los intentaré capear.
    Pero como no podía ser tan fácil, sorpresa, pérdida de aceite por el turbo... no se todavía por dónde es. De momento se ha petroleado el motor y más o menos esta localizado ahí. Ahora a investigar...
    Un saludo!
