Resultados 1 al 8 de 8
Tema: Ayuda con errores VagCom no reconocidos
    Nº de Usuario: 70242
    18-nov-2017
    santander
    VW Passat Variant Sport Tdi 190 CV DSG R-line blanco orix
    Agradecido 18 veces en 15 mensajes.
    Predeterminado Ayuda con errores VagCom no reconocidos
    Hola, le acabo de pasar el VagCom a un ibiza Fr tdi 150. Tengo una version antigua del programa y me salen unos fallos que no se lo que son, a ver si me podeis ayudar
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Monday,04,December,2017,21:06:06:32264
    Chassis Type: 1M - Seat Leon/Toledo
    Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
    VIN: VSSZZZ5FZER078299
    Address 01: Engine (J623-CKFC) Labels: None
    Part No SW: 04L 906 021 DS HW: 04L 907 309 D
    Component: R4 2,0L EDC H22 7544
    Revision: 83H22---
    Coding: 01190012032401090000
    Shop #: WSC 07020 001 1048576
    ASAM Dataset: EV_ECM20TDI01104L906021DS 002012
    ROD: N/A
    VCID: 79F3F33DF8C2731
    No ASAM data for: "EV_ECM20TDI01104L906021DS" ()
    2 Faults Found:
    11901 - ROD - Unknown Error Code
    - 7D [096]
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 49588 km
    Date: 2017.12.03
    Time: 15:12:33
    5169 - ROD - Unknown Error Code
    - 31 [167]
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Mileage: 49554 km
    Date: 2017.12.03
    Time: 14:49:02
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
    Component: EMB8 EHCB H31 0356
    Revision: 00000000 Serial number: 60114000000330
    Coding: 18EE6292242709740079060941CC241846249000608224F200 610070C002
    Shop #: WSC 00049 770 00106
    ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
    ROD: N/A
    VCID: 4B9F79F5E2DE311
    No ASAM data for: "EV_Brake1UDSContiMK100ESP" ()
    1 Fault Found:
    8291 - ROD - Unknown Error Code
    - 63 [008]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 55
    Mileage: 49601 km
    Date: 2017.12.04
    Time: 20:56:32
    Address 08: Auto HVAC (J255) Labels: None
    Part No SW: 5F0 907 044 D HW: 5F0 907 044 D
    Component: Climatronic H03 0705
    Revision: 00001K07
    Coding: 04000114202100011005000000101000
    ASAM Dataset: EV_ACClimaBHBVW37X 003017
    ROD: N/A
    VCID: 2757E5455EF6351
    No ASAM data for: "EV_ACClimaBHBVW37X" ()
    2 Faults Found:
    1048834 - ROD - Unknown Error Code
    - 02 [008]
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 51
    Mileage: 49217 km
    Date: 2017.11.28
    Time: 13:22:16
    1048835 - ROD - Unknown Error Code
    - 03 [008]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 16
    Reset counter: 54
    Mileage: 49220 km
    Date: 2017.11.28
    Time: 13:30:46
    Address 15: Airbags (J234) Labels: None
    Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
    Component: Airbag VW20 012 0189
    Revision: -------- Serial number: 003P4P0MCXB6
    Coding: 98CCC000000000005C0000CC000800000065
    ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
    ROD: N/A
    VCID: 7F071D25E6E65D1
    No ASAM data for: "EV_AirbaVW20TS6VW48X" ()
    No fault code found.
    Address 17: Instruments (J285) Labels: None
    Part No SW: 5F0 920 871 A HW: 5F0 920 871 A
    Component: KOMBI 303 2210
    Coding: 07A40A002980000800086A00000000
    ASAM Dataset: EV_DashBoardVDDMQBAB 008031
    ROD: EV_DashBoardVDDMQBAB.rod
    Address 19: CAN Gateway (J533) Labels: None
    Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
    Component: GW MQB High 125 1164
    Revision: -------- Serial number: 0001477944
    Coding: 030100F40B087300EF0006C8080F0001000100000000000000 0000000000
    ASAM Dataset: EV_GatewLear 010015
    ROD: EV_GatewLear.rod
    VCID: 3F875D25A6669D1
    Versión antigua?, para nada es versión antigua la 11.11.3, es el que tengo yo y va muy bien.
    Has cargado las label mal, has seleccionado como si fuera un Seat Leon o Toledo. Selecciona las labels bien si es un Ibiza debes seleccionar Ibiza.
    18-nov-2017
    santander
    Perdon, puse Ibiza pero es un Leon
    Nº de Usuario: 1682
    11-jun-2009
    Aluche
    Skoda Rs TFSI Powered by iCanOBD2
    Agradecido 121 veces en 84 mensajes.
    Estos son tus fallos
    MOTOR
    P023600 - Transmisor de la presión de sobrealimentación ,Señal no plausible
    P023800 - Transmisor de la presión de sobrealimentación ,Señal demasiado grande
    ABS
    U112300 - Bus de datos valor de error recibido
    CLIMA
    B10CD00 - Funcionamiento parcial debido a la gestión de energía
    P171900 - Funcionamiento parcial debido a la unidad de control del motor
    18-nov-2017
    santander
    Lo del motor me preocupa... Turbo? Alguna valvula?
    Avatar de neteiris
    Nº de Usuario: 17350
    01-dic-2012
    Passat CC 1.8 TSI
    Agradecido 326 veces en 302 mensajes.
    Es un Ibiza MQB, ese cable es antiguo para ese coche.
    Cita Iniciado por neteiris Ver Mensaje
    El autor dice que es un Ibiza FR 150 y luego dice que es un Leon. En mi opinion ese cable para un PD de ese año es correcto.
    18-nov-2017
    santander
    Parece que ya esta solucionado. Cambiar bateria y limpiar la valvula G31. Muchas gracias a todos
