Página 1 de 2 12 ÚltimoÚltimo
Resultados 1 al 10 de 12
Tema: Errores en Passat 3C
    Nº de Usuario: 30466
    23-jun-2014
    Seat Toledo 1.6 Tdi 105CV Style
    Predeterminado Errores en Passat 3C
    hola a todos. necesito que me ayudéis, me han salido estos errores en el passat y a ver si me podéis echar una mano de que puede ser esos errores...
    gracias.
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Sunday,28,January,2018,12:04:25:62939
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
    Mileage: 154370km/95921miles
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 BL HW: 03L 907 309
    Component: R4 2.0l TDI 0001SG 9977
    Revision: --H01--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 00637 572 175557
    VCID: 70EF364B6356C89E643-8025
    1 Fault Found:
    001027 - EGR Valve (N18)
    P0403 - 000 - Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 153885 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:32:57
    Freeze Frame:
    RPM: 1748 /min
    Speed: 60.0 km/h
    Load: 35.7 %
    Load: 14.9 %
    Lambda: 100.2 %
    Mass Air / Rev.: 550.0 mg/str
    Temperature: 85.5°C
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
    Component: J104 C4 440 V2 0003
    Revision: --020--- Serial number: 00000785222479
    Coding: 0000267
    Shop #: WSC 05311 000 00000
    VCID: 1F4D05F7CE4807E68D9-804A
    No fault code found.
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 CR HW: 3C0 907 044 CR
    Component: ClimatronicPQ46 132 0811
    Revision: 00132023 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 73E539471240F386991-8026
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 01000007977222
    Coding: 01800F0700041A00470A00000F00000000095D435C00010000 0000000000
    Shop #: WSC 05124 000 00000
    VCID: 71E9334F685CC1966BD-8024
    Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
    Component: Wischer 290108 003 0205
    Coding: 00046997
    Shop #: WSC 05124
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
    Component: J234__005 VW10 HI 1815
    Revision: 19013000 Serial number: 0039DP34DAC6
    Coding: 0012341
    VCID: 3B75D1677A907BC6811-806E
    Subsystem 1 - Serial number: 6333FTS615740388
    Subsystem 2 - Serial number: 6343FTS664720368
    Subsystem 3 - Serial number: 6353ETS6Q3MGSVNP
    Subsystem 4 - Serial number: 6363ETS60PUGSVNH
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 AB HW: 3C0 953 549 AB
    Component: J0527 0020
    Revision: 00026000 Serial number: 3C5953507AM
    Coding: 0000003
    VCID: 6CD7223B4F7E2C7E58B-8039
    1 Fault Found:
    00888 - Wiper Switch for Intermittent Operation (E22)
    014 - Defective - Intermittent
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 860 N HW: 3C0 920 860 N
    Component: KOMBIINSTRUMENT VD1 1216
    Revision: V0002000 Serial number: 00000000000000
    Coding: 0007105
    Shop #: WSC 78654 326 999999
    VCID: 2D51EF3FB4E4E5760F5-8078
    Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
    Part No SW: 3C0 907 530 E HW: 3C0 907 951
    Component: J533__Gateway H10 0080
    Revision: H10 Serial number: 1200P0822003B7
    Coding: F9807F060002021002
    VCID: 23450907E2202306A91-8076
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
    Component: IMMO 042 0383
    Revision: 00042000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 3979CB6F70AC49D693D-806C
    Subsystem 1 - Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1131
    Revision: 32008001 Serial number: 00000637088218
    Coding: 0000181
    Part No: 1K1 909 144 M
    Component: EPS_ZFLS Kl.134 H08 1901
    Shop #: WSC 02069 000 90108
    VCID: 3561C75F5CB4ADB6775-8060
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 042 0472
    Coding: 00910A0001860E763004941570084F0B607CA1
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1131
    Revision: 32008001 Serial number: 00000543288215
    Coding: 0000180
    VCID: 3C77D27B7F9E7CFE88B-8069
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
    Component: J540 EPB3 VW-09393 0009
    Revision: 008 Serial number: 00000000362970
    Coding: 0000057
    VCID: 29591B2F800CF956E3D-807C
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 AD
    Component: Radio GR0 034 0033
    Revision: 0003404S Serial number: VWZ2Z2H6059682
    Coding: 0040400
    Shop #: WSC 05314 000 00000
    VCID: 68DF5E2B5B86005E3C3-803D
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
    Component: J388 TUER-SG HL 0308
    Revision: 41004101 Serial number: 00000000227893
    Coding: 0000144
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
    Component: J389 TUER-SG HR 0308
    Revision: 41004101 Serial number: 00000000247648
    Coding: 0000144
    Nº de Usuario: 99
    Diesel
    Llevas kit de xenon?
    Enviado desde mi PRA-LX1 mediante Tapatalk
    Avatar de CarlosApellido1
    Nº de Usuario: 26081
    01-mar-2014
    Cualquier lugar
    WVWZZZ1KZ8 1.9 TDI
    posiblemente tengas que cambiar la egr. se te enciende la luz amarilla? ha sido un fallo intermitente, puede que borrandolo se acabe el tema, o te vuelva a salir dentro de un tiempo.
    23-jun-2014
    Cita Iniciado por luisete07 Ver Mensaje
    no solo lleva las bombillas de serie...
    23-jun-2014
    hace 1 semana se me puso el coche en limp mode, no pasaba de 100 y se encendió el testigo de los calentadores, aparque el coche 5 min y lo volví arrancar y se quito el chivato de los calentadores y el coche va bien... pero al pasar el vagcom he visto eso y no se si la avería puede ser por la EGR.
    gracias.
    Te pego la descripción de tu avería sacada de la página Oficial de Ross-Tech:
    16787 - Válvula de re-circulación de gases de escape (EGR) (N18): mal funcionamiento.
    Posibles síntomas:
    • Testigo de avería encendido en el cuadro (MIL ON).
    • Perdida de potencia (Limp-Mode).
    Posibles causas:
    • Fusible (s) defectuoso.
    • Cableado/conector de la válvula de re-circulación de gases de escape (EGR) defectuoso.
    • Válvula de re-circulación de gases de escape (EGR) (N18) atascada / defectuosa.
    Posibles soluciones:
    • Verificar fusible (s)
    • Verifique el cableado/conector de la válvula de re-circulación de gases de escape (EGR)
    • Comprobar/reemplazar la válvula de re-circulación de gases de escape (EGR)
    • Verifique los valores de EGR en el bloque de medidas del motor (Vag-Com).
    End................. ................................. ...........................................
    En tu modelo la EGR es eléctrica, no lleva válvula N18. Por tanto, verifica los fusibles del coche uno a uno, sacando cada uno de su emplazamiento (no los compruebes con ellos puestos) usa un tester o polímetro, no los mires a ojo. Que están todos bien? siguiente paso.
    Comprueba el cableado/conector de la EGR. Mira los pines de los conectores, por si hay alguno doblado o sulfatado, que los cables estén bien y no pelados, intenta medir continuidad (etc..) y si esto está correcto, mira con Vag-Com si la EGR trabaja bien, y si no, pues toca cambiarla.
    También deberías comprobar, si la mariposa de la EGR se abre/cierra al apagar el motor.
    Última edición por codi31; 29/01/2018 a las 15:12
    En el modelo BKP hay dos tipos de EGR, las de toda la vida pneumaticas y electricas.
    Basta con ver la EGR si le llega un manguito de vacio pues si lleva N18. Si no le llega ningun manguito de vacio pues es eléctrica.
    01-mar-2014
    Cualquier lugar
    WVWZZZ1KZ8 1.9 TDI
    ese coche es common rail (fijaos en los labels del modulo engine), y dudo que tenga mal el cableado, pecan de egr esos motores (me apuesto que es un 2.0 tdi 140 cr)
    Última edición por CarlosApellido1; 30/01/2018 a las 00:35
  9. El Siguiente Usuario Agradeció a CarlosApellido1 Por Este Mensaje:
    Whitsnak (31/01/2018)
  10. #9
    23-jun-2014
    si es un 2.0 TDI 140 CV CR...
  11. #10
    Si si, tienes toda la razón. Patiné dando por hecho que era un BKP solo por leer Passat 3C.
    Totalmente de acuerdo contigo, EGR cataput.
  12. El Siguiente Usuario Agradeció a Whitsnak Por Este Mensaje:
    CarlosApellido1 (31/01/2018)
