Buenas codi31 le he metido el vagcom y le e borrado los fallos directamente del modulo y PREMIO problema resuelto. codi31 eres UN GENIO
despues le e pasado un scaner y este es el resultado.
codi31 darte las gracias por tu ayuda que sin ella me huviese costado mas tiempo y quizas algunos euros.
Thursday,22,February,2018,16:58:44:21468
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WVGZZZ7L License Plate:
Mileage: 103200km-64125mi Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 22 37 46 55 56 68 69 76 77
VIN: WVGZZZ7L Mileage: 103200km-64125miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CAS) Labels: 059-907-401-CAT1.clb
Part No SW: 7L0 907 401 N HW: 7L0 907 401 H
Component: 3.0TDI EDC17G000AG 0060
Revision: 14H04--- Serial number: VWX3Z0I1900692
Coding: 04210023591F0168
Shop #: WSC 58967 001 1048576
VCID: 3664BF734214A18E94-513C
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 JK HW: 09D 927 750 JK
Component: AL 750 6A 1677
Revision: 00H75000 Serial number:
Coding: 0004456
Shop #: WSC 31414 790 00001
VCID: 000819AB5050DF3E7E-513C
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 P HW: 7L0 614 517 C
Component: ESP ALLRAD MK25E1 0304
Revision: 00H53001
Coding: 0004354
VCID: 4684CFB335F4310E04-8012
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 D HW: 3D0 909 139 D
Component: Kessy 6850
Revision: 00H22072 Serial number: VWX3Z0I1900692
Coding: 0000232
VCID: 2A5C9B0381ACF56E00-807E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 AL
Component: CLIMAtronic R/L 4537
Coding: 0021030
VCID: 7AFC6B43318C85EE30-802E
Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2002
Revision: -0004--- Serial number: --------------
Coding: 600004003B021C000000000000000000
VCID: 000819AB5750DF3E7E-8054
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 A HW: 7L0 959 655 A
Component: J234__08 VW8T 0270
Revision: 92013027 Serial number: 003C60015Z8R
Coding: 0012344
VCID: 3B72AE477E367CE66B-806E
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 F
Component: J527 3601
Coding: 0010011
VCID: 428CD3A319DC0D2E28-8016
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 890 K HW: 7L6 920 890 K
Component: J285 KOMBI-INST. 9833
Revision: KHH06V43
Coding: 0007101
Shop #: WSC 80093 222 69422
VCID: 4088D9AB13D01F3E3E-8014
Address 18: Aux. Heat Labels: 7L6-819-008.lbl
Part No: 7L6 815 071 G
Component: Standheizung E1MAC 0425
Coding: 0000000
VCID: 3664BF734114A18E94-8062
Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 890 K
Component: J533 GW-K-CAN TP20 9833
Coding: 77E2E78BC8056002
VCID: 70E8496B63F0CFBE8E-8024
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
Shop #: WSC 00000 000 00000
VCID: 010E1CAF5B5AD63671-513C
Subsystem 1 - Part No: 0AD 927 755 BG
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 7L6 035 680 B HW: 7L6 035 680 B
Component: RNS-MID H11 1202
Revision: AB001001 Serial number: VWZ6Z7J5337115
Coding: 000004000400002200
VCID: 316E8C6F687A86B6C1-8064
Address 46: Central Conv. Labels: None
Part No: 7L6 959 703
Component: Tuersteõergeraet ÈL 0202
VCID: 7AFC6B43368C85EE30-4B18
Subsystem 1 - Part No: 7L6 959 704
Component: Tuersteuergeraet HR 0202
Subsystem 2 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Subsystem 3 - Part No: 7L6 951 171 B
Component: Innenraumsensor 0020
Address 55: Headlight Range Labels: None
VCID: 55A618FFB8528A967D-8000
No Faults Found
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 397EB44F700A4EF679-806C
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 011209 054 0402
Coding: 00208941
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 N HW: 7L0 907 383 N
Component: J345 Anhaenger 0080
Revision: 4A009001 Serial number: 00008200578384
Coding: 0016385
Shop #: WSC 65792 000 24584
VCID: 3F8ADA576A2E60C647-806A
Address 76: Park Assist Labels: None
No Faults Found
Address 77: Telephone Labels: 3C0-035-730.lbl
Part No SW: 5N0 035 730 B HW: 5N0 035 730 B
Component: J412 8502
Revision: 00015000 Serial number: 0000B7A136960
Coding: 0020041
VCID: 275A623796BEC8061F-8072
End-------------------------(Elapsed Time: 03:52)--------------------------
