Hola nuevamente, bueno, hice lo que me recomendaron para tomar las mediciones, aquí paso las capturas. son todas a ralenti y a más de 85°C
Aquí los códigos que me largo, luego de borrarlos y dar una vuelta.
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Control Module Part Number: 03G 906 021 KK HW: 03G 906 021 KK
Component and/or Version: R4 2,0L EDC G000AG 9821
Software Coding: 0000078
Work Shop Code: WSC 03043 985 94088
VCID: 72EB3C4A6D0F2C8E927-8027
5 Faults Found:
012546 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 218314 km
Time Indication: 0
Date: 2000.00.00
Time: 15:08:13
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00001000
Torque: 0.0 Nm
Torque: 0.0 Nm
012545 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 218314 km
Time Indication: 0
Date: 2000.00.00
Time: 15:08:13
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00001000
Torque: 0.0 Nm
Torque: 0.0 Nm
001618 - Sensor Reference Voltage B
P0652 - 000 - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 218314 km
Time Indication: 0
Date: 2000.00.00
Time: 15:08:13
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Bin. Bits: 00100000
Bin. Bits: 00000000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00000000
053273 - Control Module for Instrument Cluster
U1019 - 000 - Missing Signal for Oil Level/Temperature
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 218314 km
Time Indication: 0
Date: 2000.00.00
Time: 15:08:17
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00001000
Bin. Bits: 00000000
(no units): 0.0
P3101 - 000 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 218314 km
Time Indication: 0
Date: 2000.00.00
Time: 15:08:13
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00001000
Torque: 0.0 Nm
Torque: 0.0 Nm
Readiness: 1 2 0 0 1
una duda, los valores del grupo 18, a 2500 rpm se ponen en 4, como pueden ver en una de las primeras imágenes subidas, eso esta bien?
Agradezco la paciencia
