Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 CD HW: 03G 906 018 CD
Component: R4 2.0l PPD1.5 G 9970
Revision: --H05--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00573 572 128432
VCID: 69D3A37D4062C31
5 Faults Found:
18000 - Altitude Sensor / Boost Pressure Sensor
P1592 - 006 - Implausible Correlation - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 1
Fault Frequency: 254
Reset counter: 109
Mileage: 244787 km
Time Indication: 0
Date: 2018.04.24
Time: 13:18:38
Freeze Frame:
RPM: 0 /min
Text: 0 Nm
Speed: 0.0 km/h
Text: 0.0 %
Voltage: 12.09 V
Text: 934 hPa
Text: 1380 hPa
16485 - Mass Air Flow Sensor (G70)
P0101 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 55
Reset counter: 183
Mileage: 247545 km
Time Indication: 0
Date: 2018.05.19
Time: 21:57:52
Freeze Frame:
RPM: 1664 /min
Text: 0 Nm
Speed: 90.0 km/h
Temperature: 39.0°C
Text: 1507 hPa
Text: 104 kg/h
(no units): 1.23
16618 - Boost Pressure Regulation
P0234 - 006 - Limit Exceeded (Overboost Condition) - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 93
Mileage: 252425 km
Time Indication: 0
Date: 2018.08.03
Time: 07:51:16
Freeze Frame:
RPM: 2112 /min
Text: 112 Nm
Speed: 110.0 km/h
Text: 33.6 %
Voltage: 14.13 V
Text: 1401 hPa
Text: 1783 hPa
16622 - Manifold Pressure / Boost Sensor (G31)
P0238 - 006 - Signal too High - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 1
Fault Frequency: 10
Reset counter: 106
Mileage: 252683 km
Time Indication: 0
Date: 2018.08.09
Time: 14:01:58
Freeze Frame:
RPM: 0 /min
Text: 0 Nm
Speed: 0.0 km/h
Text: 0.0 %
Voltage: 12.09 V
Text: 0 hPa
Text: 2993 hPa
16497 - Intake Air Temp. Sensor (G42)
P0113 - 006 - Signal too High - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 106
Mileage: 252683 km
Time Indication: 0
Date: 2018.08.09
Time: 14:02:23
Freeze Frame:
RPM: 0 /min
Text: 0 Nm
Speed: 0.0 km/h
Text: 0.0 %
Voltage: 12.09 V
Temperature: -40.0°C
Temperature: 81.0°C
Readiness: N/A
