Address 01: Engine Labels: None
Part No SW: 03C 906 057 AG HW: 03C 906 057 M
Component: BOSCH ME7.5.20 G 1514
Revision: 21H01--- Serial number: SEZ5Z0H2291212
Coding: 0000071
Shop #: WSC 06402 785 00200
VCID: 69D9D7C243B8C80A17-515E
6 Faults Found:
049153 - Powertrain Databus
U0001 - 008 - Unspecified Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 91
Reset counter: 255
Mileage: 91967 km
Time Indication: 0
Freeze Frame:
RPM: 1050 /min
Load: 99.6 %
Speed: 13.0 km/h
Temperature: 36.0°C
Temperature: 18.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
001281 - Vehicle Speed Sensor
P0501 - 004 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 49
Reset counter: 255
Mileage: 91967 km
Time Indication: 0
Freeze Frame:
RPM: 1108 /min
Load: 29.8 %
Speed: 7.0 km/h
Temperature: 16.0°C
Temperature: 16.0°C
Voltage: 0.000 V
049489 - No Communications with Airbag Control Module
U0151 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 51
Reset counter: 255
Mileage: 91967 km
Time Indication: 0
Freeze Frame:
RPM: 686 /min
Load: 24.3 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 42.0°C
Voltage: 0.000 V
049493 - No Communication with Instrument Cluster
U0155 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 2421 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 35.0°C
Voltage: 0.000 V
049508 - No Communications with HVAC Control Module (J301)
U0164 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 2379 /min
Load: 15.7 %
Speed: 6.0 km/h
Temperature: 90.0°C
Temperature: 35.0°C
Voltage: 0.000 V
049478 - No Communication with Diagnostic Gateway
U0146 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 1916 /min
Load: 60.4 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 18.0°C
Voltage: 0.000 V
Readiness: 0000 0101
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP80.lbl
Part No SW: 6Q0 907 379 AS HW: 6Q0 907 379 AS
Component: ESP 8.0 front H05 0003
Revision: 00000000 Serial number: 00000000000000
Coding: 0002556
VCID: 0E13C45E1A964F3222-5122
2 Faults Found:
01312 - Powertrain Data Bus
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 7
Reset counter: 61
Mileage: 91967 km
Time Indication: 0
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 92066 km
Time Indication: 0
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 F
Component: 000B BN-SG. 2S36
Coding: 16524
Shop #: WSC 06402
VCID: 3E73549E3AB69FB292-5122
1 Fault Found:
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 AE
Component: 0G AIRBAG VW5 0C 0010
Coding: 12359
Shop #: WSC 06401
VCID: 7AFB988E661E7392EE-5122
1 Fault Found:
Address 17: Instruments Labels: 6L0-920-xx3-17.lbl
Part No: 6L0 920 803
Component: KOMBIINSTRUMENT AGD V04
Coding: 00105
Shop #: WSC 00000
VCID: 68DFD2C608B2F10208-5140
1 Fault Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0305 GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 06402
VCID: 70EFBAA6306239C250-5140
1 Fault Found:
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10111
Shop #: WSC 06402
VCID: 6DD1A3D22750D42A7B-5140
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
