Aqui tienes tu label. En tu autoscan veo que alguien ha cambiado el coding del motor y tu cuadro de instrumentos tambien aparece WSC 0000. Parece que alguien ha cambiado algo en el coche. Prueba a hacer LOGIN antes de meter el CODING. Supongo que en tu vagcom tienes configurado algun numero de WSC, sino es asi no te cogera ningun CODING. Ya contaras como te ha ido.
; VCDS Label File
; Copyright © 2005-2009 Ross-Tech, LLC
; Skoda Superb (3U)
; Component: J104 - Brake Electronics (#03) - Bosch 5.7
; P/N: 3U0-614-517-???
; includes measuring blocks, basic setting, coding and login
; created on 09/Dec/2005 by Sebastian Stange (sebastian@ross-tech.com)
; last modificationon on 06/Mar/2009
; requires VCDS 805.0 or newer
; measuring blocks & basic setting
001,0,Wheel Speed
001,1,Wheel Speed,Front Left,Display Range: 0.0...255.0 km/h
001,2,Wheel Speed,Front Right,Display Range: 0.0...255.0 km/h
001,3,Wheel Speed,Rear Left,Display Range: 0.0...255.0 km/h
001,4,Wheel Speed,Rear Right,Display Range: 0.0...255.0 km/h
B001,0,Steering Angel Sensor (G85) Alignment
B001,1,Steering Angel,Sensor (G85),
B001,2,Alignment, ,
B001,3,Alignment,Status,Specification: OK
B001,4, , ,
002,0,Switches && Buttons
002,1,Brake Test Switch,,Display Range: 0/operated
002,2,Brake Light Switch,,Display Range: 0/operated
002,3,Parking Brake,Button,Display Range: 0/operated
002,4,ESP-Passive,Button,Display Range: 0/operated
003,0,Engine Data
003,1,Engine Speed
003,2,Engine Torque
003,3,Engine Torque,(loss)
003,4,Throttle Valve Angle
004,1,Standing Time
004,2,EDL-T Flag,,Display Range: ON/OFF\nSpecification: OFF
005,1,Steering Angle,Sensor (G85),Display Range: -720.0...+720.0 °\nTolerance (when straight): ±5.0 °
005,2,Rotation Rate,,Display Range: -69.0...+69.0 °/s
005,3,Brake Pressure,,Display Range: -41.0...+292.0 bar\n40.0 bar = Short to Ground\n290.0 bar = Short to Plus
005,4,Transverse,Acceleration,Display Range: -25.0...+25.0 m/s²
006,1,Supply Voltage,(Terminal 30),Specification: 9.8...17.4 V
006,2,Valve Relay,,Display Range: ON = OK / OFF = not OK
006,3,Return Flow Pump,,Display Range: ON/OFF
006,4,Work Shop Code
008,1,Steering Angle,Sensor (G85),Specification: Steer. ang. 1\nDisplay Range: Steer. ang. 0/Steer. ang. 1
008,2,Transmission,,Display Range: Transm. 0/Transm. 1
008,3,Engine,,Specification: Engine 1\nDisplay Range: Engine 0/Engine 1
008,4,Instrument Cluster,,Specification: Instruments 1\nDisplay Range: Instruments 0/Instruments 1
125,0,CAN-Databus Communication (Powertrain)
125,1,Steering Angle,Sensor (G85),Specification: Steer. ang. 1\nDisplay Range: Steer. ang. 0/Steer. ang. 1
125,2,Transmission,,Display Range: Transm. 0/Transm. 1
125,3,Engine,,Specification: Engine 1\nDisplay Range: Engine 0/Engine 1
125,4,Instrument Cluster,,Specification: Instruments 1\nDisplay Range: Instruments 0/Instruments 1
; login/coding-ii
L00,Brake Electronics (J104/Bosch 5.7) Login/Coding-II
L01,09575 = AZM/AWT (Manal Transmission)
L02,09397 = AMX/BBG (Automatic Transmission)
L03,09395 = AMX (Manual Transmission)
L04,09357 = AYM/BDG (Automatic Transmission)
L05,09355 = AYM/BDG/BSS (Manual Transmission)
L06,09555 = AWX/AVB/BSV (Manual Transmission)
L07,09557 = AVF (Automatic Transmission)
L08,09577 = AWT (Automatic Transmission)
L09,
L10,Note: After Login/Coding-II has been carried out you need to recode the Control Module.
L11,
L12,40168 = Basic Settings Enabling (i.e. mandatory prior to Steering Angle Sensor Alignment)
; coding
C00,Brake Electronics (J104/Bosch 5.7) Coding
C01,04275 = AZM/AWT (Manal Transmission)
C02,04497 = AMX/BBG (Automatic Transmission)
C03,04495 = AMX (Manual Transmission)
C04,04457 = AYM/BDG (Automatic Transmission)
C05,04455 = AYM/BDG/BSS (Manual Transmission)
C06,04255 = AWX/AVB/BSV (Manual Transmission)
C07,04257 = AVF (Automatic Transmission)
C08,04277 = AWT (Automatic Transmission)
C09,
C10,Note #1: Coding is accepted after a specific Login has been carried out.
C11,Note #2: After successful Coding the Steering Angle Sensor Alignment needs to be carried out.
Lo de inicio de sesión específico a que se refiere ?
