Yo te aconsejaría primeramente cambiar bomba de agua y cableado de inyectores, podrías poner una captura de pantalla del Vagcom y así ver qué fallos da el coche.
En primer lugar os pongo lo primero que me dio cuando lo compré y que borré.
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Tuesday,17,September,2019,17:01:09:62939
VIN: WVWZZZ3CZ8E147111 License Plate: 0490FZJ
Mileage: 207450km-128903mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 72 76
VIN: WVWZZZ3CZ8E147111 Mileage: 207450km/128903miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 FG HW: 03G 906 018 FG
Component: R4 2.0l PPD1.5 G 2146
Revision: --H55--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 05314 000 00000
VCID: 6FED35377E68D7667D9-803A
1 Fault Found:
004720 - PD Unit Injector: Cylinder 4 (N243)
P1270 - 006 - Regulation Range Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 3
Reset counter: 26
Mileage: 206178 km
Time Indication: 0
Date: 2019.08.14
Time: 08:51:36
Freeze Frame:
RPM: 960 /min
Torque: 16.0 Nm
Speed: 41.0 km/h
75.66 %
Text: 5.000 uF
Text: 14.25 mJ
Text: 10 mJ
Raw, Form. N/A: 000 000 000
Readiness: N/A
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 050 D HW: 02E 927 770 AE
Component: GSG DSG 081 1404
Revision: 04708010 Serial number: 00000711171380
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 132559C732805386391-8046
No fault code found.
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 K HW: 3C0 614 109 D
Component: J104 C4 440 V2 0005
Revision: --020--- Serial number: 00000776700561
Coding: 0002318
Shop #: WSC 05770 572 51263
VCID: 264310139112D62ECEF-8073
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 DA HW: 3C0 907 044 DA
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 63C54907A2A06306E91-8036
2 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 3
Fault Frequency: 46
Reset counter: 174
Mileage: 206783 km
Time Indication: 0
Date: 2019.09.13
Time: 11:12:33
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 61
Reset counter: 174
Mileage: 206784 km
Time Indication: 0
Date: 2019.09.13
Time: 14:09:33
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007867499
Coding: E78A8F0700041A00470A00000F000000000B5D435C00010000 0000000000
Shop #: WSC 05124 000 00000
VCID: 71E9334F685CC1966BD-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 201007 003 0205
Coding: 00046997
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 061207 046 0204
Coding: 00208933
Shop #: WSC 05124
1 Fault Found:
01598 - Drive Battery Voltage
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 79
Reset counter: 174
Mileage: 206787 km
Time Indication: 0
Date: 2019.09.13
Time: 14:12:00
Freeze Frame:
ON
Voltage: 14.40 V
ON
ON
OFF
OFF
ON
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__005 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPQLAHWR
Coding: 0012341
Shop #: WSC 05311 000 00000
VCID: 3B75D1677A907BC6811-806E
Subsystem 1 - Serial number: 6333FTS654583167
Subsystem 2 - Serial number: 6343FTS648163167
Subsystem 3 - Serial number: 6353ETS63RF510KP
Subsystem 4 - Serial number: 6363ETS6PNF510KH
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AC HW: 3C0 953 549 AC
Component: J0527 0020
Revision: 00026000 Serial number: 3C9953507AR
Coding: 0001212
VCID: 6DD12F3F746425764F5-8038
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 80093 222 69422
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P07C030648
Coding: FD817F0E0002022002
VCID: 23450907E2202306A91-8076
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 162
Mileage: 206783 km
Time Indication: 0
Date: 2019.09.13
Time: 11:12:11
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 206783 km
Time Indication: 0
Date: 2019.09.13
Time: 11:12:16
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 799 G HW: 3C0 959 799 G
Component: IMMO 070 0383
Revision: 00070000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 3D71DF7F648475F6BF5-8068
Subsystem 1 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1131
Revision: 31008001 Serial number: 00000524479118
Coding: 0000247
VCID: 3C77D27B7F9E7CFE88B-8069
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.136 H08 1901
Shop #: WSC 02069 000 90108
VCID: 3561C75F5CB4ADB6775-8060
Address 46: Central Conv. Labels: 3C0-959-799-46.clb
Component: KESSY PQ46 R 070 0227
Coding: 1991020051430E763004941570004FCE707801030424A0
Shop #: WSC 00912 572 81616
Subsystem 1 - Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Subsystem 2 - Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C
Component: Innenraumueberw.004 0611
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1131
Revision: 31008001 Serial number: 00000020579116
Coding: 0000246
Shop #: WSC 54581 002 1048576
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
Mileage: 207266 km
Time Indication: 0
Date: 2019.09.16
Time: 16:16:32
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000273324
Coding: 0000057
VCID: 29591B2F800CF956E3D-807C
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 B HW: 5M0 907 357 B
Component: AFS-Steuergeraet X024
Revision: 00H01000 Serial number:
Coding: 2311169
VCID: 3365F94752C0B386591-8066
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Lst.-Modul l 0004
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Lst.-Modul r 0002
Coding: 00000035
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000078347
Coding: 0000208
VCID: 70EF364B6356C89E643-8025
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000088249
Coding: 0000208
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 C HW: 3C0 919 283 C
Component: Parkhilfe 8-Kan 004 0013
Revision: 00004000 Serial number: 90640733203132
Coding: 0001024
y esta es la última que le hice:
Mileage: 210580km-130848mi Repair Order:
VIN: WVWZZZ3CZ8E147111 Mileage: 210580km/130848miles
01-Engine -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
Coding: 0000078
Readiness: N/A
Coding: 0000020
Coding: 0002318
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 133
Reset counter: 208
Mileage: 206783 km
Time Indication: 0
Date: 2019.09.13
Time: 11:12:33
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 226
Reset counter: 208
Mileage: 206784 km
Time Indication: 0
Date: 2019.09.13
Time: 14:09:33
Coding: 00046997
Shop #: WSC 05124
Coding: 00208933
Shop #: WSC 05124
1 Fault Found:
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 254
Reset counter: 248
Mileage: 206787 km
Time Indication: 0
Date: 2019.09.13
Time: 14:12:00
Freeze Frame:
ON
Voltage: 14.40 V
ON
ON
OFF
OFF
ON
Coding: 0012341
Coding: 0001212
Coding: 0007105
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 162
Mileage: 206783 km
Time Indication: 0
Date: 2019.09.13
Time: 11:12:11
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 206783 km
Time Indication: 0
Date: 2019.09.13
Time: 11:12:16
Coding: 0000247
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Mileage: 208110 km
Temperature: 44.0°C
Voltage: 5.80 V
Voltage: 5.60 V
1 Fault Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 244
Mileage: 210549 km
Time Indication: 0
Date: 2019.10.04
Time: 03:42:43
Coding: 0000246
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 229
Mileage: 207266 km
Time Indication: 0
Date: 2019.09.16
Time: 16:16:32
Coding: 0000057
Coding: 2311169
Coding: 00000035
Coding: 00000035
Address 56: Radio
Cannot be reached
Coding: 0000208
Coding: 0000208
Coding: 0001024
Y después de esto lo volví a borrar y lo dejé así:
Gateway Installation List: 3C0 907 530 E
El del voltaje que sale creo que es por una cosa que me pasó un par de veces.
Me parece que fue las dos veces tras haber arrancado el motor. Parece que se viniera abajo la tensión, la dirección por un instante se pone dura, y las luces(xenon) parpadean o se apagan.
También deciros que hice el basic settings, como os puse unos mensajes antes, y me ha querido dar la sensación de que ahora sale un ligerísimo calor por uno de los lados nada más, cuando antes no salia por ninguno.
Gracias por todas las ayudas!!!!
Última edición por guillepr; 13/10/2019 a las 21:27
