Gracias por la respuesta starwack. Aquí te dejo toda la inforamción del autoscan.
Saturday,12,October,2019,13:02:44:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
VIN: TMBCS61Z552031103 License Plate:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBCS61Z552031103 Mileage: 265750km-165129miles
00-Steering Angle Sensor -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 DJ HW: 028 101 188 3
Component: R4 1,9L EDC G000SG 6250
Revision: 12345678 Serial number: SKZ7Z0D2777988
Coding: 0000071
Shop #: WSC 73430 790 00000
VCID: 6ED415FA790C45310B-803A
2 Faults Found:
18107 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.54 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 1.0
16952 - Cruise Control Switch (E45)
P0568 - 000 - Implausible Signal
Freeze Frame:
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021121
VCID: 3A7CE9AA75C4D991E7-806E
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1Z0 820 047
Component: Climatic PQ35 004 0201
Shop #: WSC 00000 000 00000
VCID: 70E80B82633853C119-8024
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001356631
Coding: 01000E020004140000110D000000000000087F075C
Subsystem 1 - Part No: 1Z1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 73430
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
Component: 08 AIRBAG VW8 023 0700
Revision: 06023000 Serial number: 00385D0MU6ST
Coding: 0012344
VCID: 316ECE86A8B21AC956-8064
Subsystem 1 - Serial number: 6332MSME0E0D1707
Subsystem 2 - Serial number: 6342MSME3E0F3A07
Subsystem 3 - Serial number: 6351HSME0C4D1C05
Subsystem 4 - Serial number: 6361HSME305A7D04
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0000022
VCID: 3566FA965CDA36E90A-8060
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1Z0 920 810 D
Component: KOMBIINSTRUMENT VD1 3560
Coding: 0003101
Shop #: WSC 05572 843 13298
VCID: 3362C48E52AE28D924-8066
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104B070456
Coding: 3D3F0340071302
VCID: 295E26E6806262099E-807C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3560
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0165
Coding: 0000116
VCID: 74E0079217206FE1FD-8020
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.2 1502
VCID: 3068CB82A3B813C159-8064
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 00F802007F2D8505084F010004
Shop #: WSC 00425 572 56388
VCID: 7BF22CAE3A7E2099BC-802E
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000116
VCID: 75E63A961C5A76E9CA-8020
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 A HW: 01. 01. 03
Component: Radio FO3 0008
Coding: 0000400
VCID: 2C50DFF28F90772165-8078
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0219
Coding: 0000048
VCID: 2F6AC8FEBE860C3940-807A
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
End-------------------------(Elapsed Time: 01:28)--------------------------
