Resultados 1 al 4 de 4
Tema: Motor VW jetta 1.4 tsi 140cv 2007 no va fino
    Nº de Usuario: 30009
    09-jun-2014
    Cerca de Portugal :)
    Seat Cordoba 1.9 TDI 101CV AXR
    Predeterminado Motor VW jetta 1.4 tsi 140cv 2007 no va fino
    Buenos dias,acudo a vosotros ya que el motor de mi jetta no funciona fino,noto tirones al acelerar y unas decimas de incremento en el consumo.Hacia años que no tocaba el vagcom,le hice un log y escan con las averias que salen.
    Thursday,25,February,2021,21:34:23:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    VIN: WVWZZZ1KZ7M138246 License Plate:
    Mileage: 237690km-147693mi Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1KZ7M138246 Mileage: 237690km/147693miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: Malfunction 1010
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: 03C-906-032-BLG.lbl
    Part No SW: 03C 906 032 E HW: 03C 906 032
    Component: MED17.5.1 G 9970
    Revision: 69H07--- Serial number: VWZ7Z0G9027596
    Coding: 0000072
    Shop #: WSC 00532 572 88453
    VCID: 1F4D05F7CE4807E68D9-804A
    2 Faults Found:
    000769 - Cylinder 1
    P0301 - 000 - Misfire Detected - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 22
    Reset counter: 255
    Mileage: 236881 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 21:21:26
    Freeze Frame:
    RPM: 1161 /min
    Load: 36.8 %
    Speed: 0.0 km/h
    Temperature: 30.0°C
    Temperature: 14.0°C
    Absolute Pres.: 970.0 mbar
    Voltage: 14.224 V
    000772 - Cylinder 4
    P0304 - 000 - Misfire Detected - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 22
    Reset counter: 255
    Mileage: 237482 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:26:22
    Freeze Frame:
    RPM: 1201 /min
    Load: 25.5 %
    Speed: 0.0 km/h
    Temperature: 17.0°C
    Temperature: 9.0°C
    Voltage: 14.351 V
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Coding: 0002690
    Shop #: WSC 00066 000 00000
    VCID: 73E539471240F386991-8026
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1K0 907 044 BH HW: 1K0 907 044 BH
    Component: ClimatronicPQ35 090 0909
    Revision: 00090016 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 6ED328337962DE6E76F-803B
    No fault code found.
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
    Component: Bordnetz-SG H52 2002
    Revision: 00H52000 Serial number: 00000000531918
    Coding: E5050E2700041500470A00000F00000000095D035C0000
    VCID: 6CD7223B4F7E2C7E58B-8039
    Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 210207 020 0501
    Coding: 00038805
    Shop #: WSC 00000
    Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
    Component: RLS 020107 020 0105
    Coding: 00208933
    Shop #: WSC 00000
    1 Fault Found:
    01333 - Door Control Module; Rear Left (J388)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 20
    Mileage: 236095 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.35 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 2J AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD0YWFHI
    Coding: 0012874
    VCID: 3D71DF7F648475F6BF5-8068
    Subsystem 1 - Serial number: 6332MSME5F5B785F%
    Subsystem 2 - Serial number: 6342MSME16111537/
    Subsystem 3 - Serial number: 6351HSME0C4810642
    Subsystem 4 - Serial number: 6361HSME31304834.
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
    Component: J0527 036 0070
    Coding: 0002021
    VCID: 8109E38FD8FC51161BD-80D4
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K0 920 873 A HW: 1K0 920 873 A
    Component: KOMBIINSTRUMENT 3HL 1610
    Revision: V0003000 Serial number: VWZ7Z0G9027596
    Coding: 0019103
    Shop #: WSC 80093 222 71269
    VCID: 2A5BE423850AF24EEA7-807F
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H04 0021
    Revision: H04 02 Serial number: 180207F1000262
    Coding: 3D3F074007001002
    VCID: 2F6DF537BEE897663D9-807A
    2 Faults Found:
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 19
    Mileage: 235400 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 21:47:22
    01305 - Databus for Infotainment
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 1
    Fault Frequency: 254
    Reset counter: 253
    Mileage: 234103 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:41:43
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO 3HL 1610
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
    Component: J386 TUER-SG FT 1133
    Revision: 31008001 Serial number: 00000049078125
    Coding: 0000180
    VCID: 3C77D27B7F9E7CFE88B-8069
    2 Faults Found:
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Reset counter: 253
    Mileage: 234103 km
    Time Indication: 0
    00109 - Left Mirror Turn Signal Lamp (L131)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 5
    Reset counter: 253
    Mileage: 0 km
    Time Indication: 0
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 L
    Component: EPS_ZFLS Kl.069 H07 1806
    VCID: 3467FA5B57CEB4BE40B-8061
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0203
    Revision: 00020000 Serial number: 00000000000000
    Coding: 80900A000106087F2D0484056008CF03E0FC00
    VCID: 8305E987C2E04306091-80D6
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
    Component: J387 TUER-SG BT 1133
    Revision: 31008001 Serial number: 00000032978117
    Coding: 0000436
    2 Faults Found:
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
    Freeze Frame:
    Fault Priority: 3
    Reset counter: 253
    Mileage: 0 km
    Time Indication: 0
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 3
    Fault Frequency: 30
    Reset counter: 30
    Mileage: 0 km
    Time Indication: 0
    Address 56: Radio Labels: None
    Part No SW: 3TD 035 156 HW: 3TD 035 156
    Component: RadioSK46MID 006 0010
    Coding: 010004240410
    Shop #: WSC 00078 790 00000
    VCID: FF0D65776E0827E66D9-80AA
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
    Component: J388 TUER-SG HL 1120
    Revision: 11006001 Serial number: 00000001185899
    Coding: 0000144
    3 Faults Found:
    00098 - Rear Left Central Locking (Safe) Motor (V163)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 46
    Reset counter: 253
    Mileage: 234103 km
    Time Indication: 0
    00930 - Locking Module for Central Locking; Rear Left (F222)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Reset counter: 38
    Mileage: 234103 km
    Time Indication: 0
    01554 - Motors for Central Locking; Rear Doors; Lock
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 89
    Reset counter: 38
    Mileage: 0 km
    Time Indication: 0
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
    Component: J389 TUER-SG HR 1120
    Revision: 11006001 Serial number: 00000001190827
    Coding: 0000144
    VCID: 3E73D87369826EEEA6F-806B
    Address 76: Park Assist Labels: 1K0-919-283.lbl
    Part No: 1K0 919 283 A
    Component: 12 Einparkhilfe 0101
    VCID: 2D51EF3FB4E4E5760F5-8078
    Última edición por gasalb; 26/02/2021 a las 09:34
    Te da fallos de encendido en varios cilindros.
    Empezaría por cambiar bujias y bobinas
    gasalb (27/02/2021)
    09-jun-2014
    Ok Zx10,las bujias son nuevas,cambiare las bobinas,muchas gracias
    Enviado desde mi M2007J20CG mediante Tapatalk
    Nº de Usuario: 49442
    14-dic-2015
    gernika
    audi, a3, axv
    Agradecido 39 veces en 39 mensajes.
    cambia las bobinas de los cilindros 2 y 3 con las de 1 y 4.
    si las bobinas 1 y 4 estuvieran mal, debería darte fallos en los cilindros 2 y 3 después del intercambio arriba mencionado.
    suerte.
  6. El Siguiente Usuario Agradeció a belkor Por Este Mensaje:
    gasalb (27/02/2021)
