Cuesta lo mismo hacerlo completo.
Asi que completo y lo cuelgas por aquí.
Buenas compañeros no he tenido tiempo de pasar vagcom hasta ahora. Dejo los resultados. Gracias.
Tuesday,02,March,2021,12:59:44:61752
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
VIN: WVWZZZ1KZ6B023115 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ6B023115 Mileage: 290590km-180564miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 CB HW: 028 101 190 0
Component: R4 1,9L EDC 0000SG 6176
Revision: 12345678 Serial number: VWZ7Z0E2379133
Coding: 0000071
Shop #: WSC 00066 001 57865
VCID: 6597B3BD796ED5A3E04-8030
2 Faults Found:
16486 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low
Freeze Frame:
RPM: 924 /min
Torque: 28.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 65.3 %
Bin. Bits: 11000100
Mass Air / Rev.: 340.0 mg/str
Mass Air / Rev.: 0.0 mg/str
16955 - Brake Switch (F)
P0571 - 000 - Implausible Signal - MIL ON
Freeze Frame:
RPM: 0 /min
Torque: -98.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.92 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Bin. Bits: 0 00 0
Readiness: 0 0 1 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021121
Shop #: WSC 00046 412 08192
VCID: 40D94229C68CD08B332-8014
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AT
Component: ClimatronicPQ35 066 0606
Shop #: WSC 00000 000 00000
VCID: 79AFEFCDE5D6414334C-802C
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003376266
Coding: A1890F2700041800001400001400000000097F075C
Shop #: WSC 11111 111 45725
VCID: 2B0305855F0A23D3F60-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00063445
Shop #: WSC 11111
3 Faults Found:
00988 - Lamp for Brake Light; Right (M10)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 121
Mileage: 290590 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.75 V
ON
ON
OFF
OFF
OFF
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 121
Mileage: 290590 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.75 V
ON
ON
OFF
OFF
OFF
01064 - Terminal 58d; Interior Dimming
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 121
Mileage: 290590 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
Component: 2E AIRBAG VW8 015 2100
Revision: 03015000 Serial number: 0038ED0GF4B+
Coding: 0012869
VCID: 372B29F593429733828-8062
Subsystem 1 - Serial number: 6332MSME0A5A133BE
Subsystem 2 - Serial number: 6342MSME0A730C39G
Subsystem 3 - Serial number: 6351HSME07701028Z
Subsystem 4 - Serial number: 6361HSME0778457DJ
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000012
Shop #: WSC 00046 412 991232
VCID: 76B5E4F1D4C82E3B59E-8022
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 862 B
Component: KOMBIINSTRUMENT VDD 1012
Coding: 0003103
Shop #: WSC 11111 111 11111
VCID: 290FFF8D55F631C304C-807C
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010562083BF
Coding: 3D0F0B40070000
Shop #: WSC 00046 412 1507328
VCID: 2A0D008150F03ADB0D6-807E
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 121
Mileage: 290590 km
Time Indication: 0
Date: 2000.00.00
Time: 22:44:20
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1012
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2313
Coding: 0000052
Shop #: WSC 00046 412 843776
VCID: 363524F194486E3B99E-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 323D18E17820721BB56-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 11C802487F2D8405484A06F010CC
VCID: 78A9EAC9DEDC584B4B2-802C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000052
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D070B9D611E2DE3E84-8078
End----------(Elapsed Time: 01:00, VBatt start/end: 12.9V/12.5V)-----------
