hola compañeros ,,,,a ver si me podeis hechar una mano ,,,esta tarde fui a arrancar el coche ,,,daba contacto se encendian las luces del cuadro,,,pero en cuanto giro para arrancar se me apaga el cuadro y no aranca ....
paso scan del vagcom y me da estos errores.
Saturday,27,March,2021,16:06:05:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
VIN: VSSZZZ6LZ5R133681 License Plate:
Mileage: 172880km-107422mi Repair Order:
Chassis Type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ5R133681 Mileage: 172880km-107422miles
Address 01: Engine Labels: 038-906-019-AXR.lbl
Part No: 038 906 019 NE
Component: 1,9l R4 EDC 0400SG 6119
Coding: 00102
Shop #: WSC 06441
VCID: 67DA60DE05F6947948-4B18
VSSZZZ6LZ5R133681 SEZ7Z0E2888471
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
Part No SW: 6Q0 907 379 AA HW: 6Q0 907 379 AA
Component: ABS 8.0 front H03 0001
Revision: 00000000 Serial number: 00000000000000
Coding: 0000008
Shop #: WSC 40168 785 00200
VCID: 7CF02FB23C7027A1B5-513C
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 B
Component: CLIMAtronic PQ24 0301
Shop #: WSC 00000 000 00000
VCID: 25462AD6EF7A4669BA-515A
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00012
Shop #: WSC 06441
VCID: 3C70EFB22CF0E7A1F5-515A
5 Faults Found:
01598 - Drive Battery Voltage
07-00 - Signal too Low
01309 - Power Steering Control Module (J500)
49-10 - No Communications - Intermittent
01321 - Control Module for Airbags (J234)
01314 - Engine Control Module
00778 - Steering Angle Sensor (G85)
49-00 - No Communications
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 AD
Component: 02 AIRBAG VW5 0010
Coding: 12338
Shop #: WSC 06441
VCID: 79FE36A663421289AE-515A
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 801 A
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 00142
Shop #: WSC 00000
VCID: 275A20DEC576547988-513C
2 Faults Found:
01176 - Key
07-10 - Signal too Low - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 006D GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06441
VCID: 70E80B82303853C119-513C
4 Faults Found:
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10111
Shop #: WSC 06441
VCID: 6FEA08FE2D064C3900-515A
1 Fault Found:
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 0M Komfortgerát 0002
Coding: 00067
Shop #: WSC 48168
VCID: 3D76E2B637EAEEA9C2-4B00
Subsystem 1 - Part No: 6Q2959802A
Component: 0M Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 6Q2959801A
Component: 0M Tõrsteuer.BF KLO 0202
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
End-------------------------(Elapsed Time: 02:55)--------------------------
stage1 100@135cv , ecu bimapa , caja válvulas out , EGR off , lunas tintadas , rejillas Cupra , llantas 16 sport edición 130,,, detalles pintura cupra
