A |
39 |
A |
40 |
Right central locking lock unit input signal (Safe) |
x |
x |
x |
A |
41 |
Rear left door contact switch input signal |
x |
x |
x |
A |
42 |
Input for earth - central locking (31) |
x |
x |
x |
A |
43 |
Washer pump motor and rear window wiper motor signal output |
x |
x |
x |
A |
44 |
Front right side light bulb signal output |
x |
x |
x |
A |
45 |
High-level brake light bulb signal output |
x |
x |
x |
A |
46 |
Tank filler flap locking motor signal output (+) |
x |
x |
x |
A |
47 |
A |
48 |
Central locking motor signal output in rear left door (-) |
x |
x |
x |
A |
49 |
Central locking motor signal output in rear right door (+) |
x |
x |
x |
A |
50 |
A |
51 |
A |
52 |
B |
1 |
Supply input (30), central locking |
x |
x |
x |
B |
2 |
x |
x |
x |
B |
3 |
B |
4 |
B |
5 |
Tank filler flap locking motor signal output (-) |
x |
x |
x |
B |
6 |
B |
7 |
Central locking motor signal output in rear left door (+) |
x |
x |
x |
B |
8 |
Central locking motor signal output in rear right door (-) |
x |
x |
x |
B |
9 |
B |
10 |
B |
11 |
Rear lid release motor signal output (+) |
x |
x |
x |
B |
12 |
Relay 15 signal output |
x |
x |
x |
B |
13 |
B |
14 |
Heated rear window warning lamp signal output |
x |
x |
x |
B |
15 |
Illumination regulators - switches and instruments signal output (58d) |
x |
x |
x |
B |
16 |
Sliding sunroof adjustment control unit signal output |
x |
x |
x |
B |
17 |
Central locking deadlock function warning lamp -SAFE- signal output |
x |
x |
x |
B |
18 |
Convenience locking signal output |
x |
x |
x |
B |
19 |
B |
20 |
B |
21 |
Heated front seats control unit signal output |
x |
x |
x |
B |
22 |
Heated rear window relay signal output |
x |
x |
x |
B |
23 |
B |
24 |
Hazard warning light system warning lamp signal output |
x |
x |
x |
B |
25 |
B |
26 |
Central locking motor signal output (Safe) in rear left door (+) |
x |
x |
x |
B |
27 |
Central locking motor signal output (Safe) in rear right door (+) |
x |
x |
x |
B |
28 |
Relay X signal output |
x |
x |
x |
B |
29 |
Relay 50 signal output |
x |
x |
x |
B |
30 |
Switches and instruments illumination regulator signal earth input |
x |
x |
x |
B |
31 |
B |
32 |
B |
33 |
LIN bus 1 (rain and light detector sensor) |
x |
x |
x |
B |
34 |
B |
35 |
B |
36 |
LIN bus 2 (alarm) |
x |
x |
x |
B |
37 |
Signal output for interior monitoring off warning lamp |
x |
x |
x |
B |
38 |
Fuel pump control unit signal output |
x |
x |
x |
B |
39 |
B |
40 |
Headlight washer system relay signal output |
x |
x |
x |
B |
41 |
Horn signal output |
x |
x |
x |
B |
42 |
Supply input (30) ignition |
x |
x |
x |
B |
43 |
Interior light (30G) supply output signal |
x |
x |
x |
B |
44 |
B |
45 |
B |
46 |
B |
47 |
B |
48 |
B |
49 |
B |
50 |
B |
51 |
Light switch input signal (58d) |
x |
x |
x |
B |
52 |
Input for earth (31), left lights |
x |
x |
x |
