El fallo del airbag me lo ha dado tambien a mi, creo que fue por desconectar el cuadro con el contacto puesto... me salio averia...
Acabo de realizar mi primer test y me da estos errores, ¿que puede ser?
VCDS Version: Release 805.0
Data version: 20080625
Friday,27,November,2009,12:00:26:26365
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: ********************* Mileage: 124110km/77118miles
00-Steering Angle Sensor -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 B HW: 028 101 147 8
Component: R4 1,9L EDC 0000SG 5645
Revision: 12345678 Serial number: VWZ7Z0D9790679
Coding: 0000071
Shop #: WSC 00046 000 00000
1 Fault Found:
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 42.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000100
Temperature: 16.2°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021121
Shop #: WSC 00046 412 08192
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 K
Component: ClimatronicPQ35 061 0201
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 L HW: 1K0 937 049 L*
Component: Bordnetz-SG 1.0 H29 0701
Revision: 00029000 Serial number: 00000001162652
Coding: A5890F0600041800001400001400000000
Shop #: WSC 00046 412 63078
Part No: 1K1 955 119 B
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00046
1 Fault Found:
00061 - Footwell Lights
012 - Electrical Fault in Circuit
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
Component: 01 AIRBAG VW8 022 0600
Revision: 05022000 Serial number: 0033JD0C5EG%
Coding: 0012337
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel Labels: 1K0-953-549.lbl
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0002012
Shop #: WSC 00046 412 442368
Part No: XXXXXXXXXXX
Component: Lenkradmodul 004 0030
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 860 L
Component: KOMBIINSTRUMENT VDD 3354
Coding: 0001101
Shop #: WSC 07383 244 67381
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 21001044052562
Coding: 3D3F0B40070002
Shop #: WSC 00046 412 434176
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3354
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0112
Coding: 0000052
Shop #: WSC 00046 412 630784
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.2 1301
Address 46: Central Conv. Labels: 1K0-959-433-46.lbl
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 58E802087F2D8404084F0100
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 J
Component: Radio GR0 0014
Revision: 0001002S Serial number: VWZ2Z2D1543195
Coding: 0020200
Address 62: Door,Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Component: Tuersteuergeraet 06 0202
Coding: 0000016
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
End ------------------------------------------------
Última edición por Rapete; 28/11/2009 a las 19:19
-Sólo usuarios registrados pueden ver links. Por favor, regístrate en el foro haciendo click AQUI.
Silver Reflex, ESP, Bilstein B6, Tempomat, Asientos deportivos, Climatizador Bi-zona, Volante multifunción, Sensor de presión neumáticos, Parrot 3100.
el del motor pone no se qué del cilindro 2....
has probado a borrarlos a ver si te volvian a salir?? el del airbag pone que es intermitente, lo mismo si lo borras se te quita....
Lo del motor es el calentador del cilindro 2.
A mi me ha dado alguna vez y es porque en mi caso, el cableado del calentador va en una especie de gomaespuma rígida que con el calor se acaba partiendo y no hace buen contacto.
Muchas gracias, probare a borrar lo errores y ver si reaparecen. ¿Cuando vuelvo a revisarlo? A la semana, al dia, al mes??
Gracias.
Última edición por Rapete; 28/11/2009 a las 19:21
Si no, tambien puedes sacar el calentador y darle corriente directamente para ver si se pone incandescente. Asi lo descartas.
Peugeot 308 2023 25000 KM Sólo usuarios registrados pueden ver links. Por favor, regístrate en el foro haciendo click AQUI.
BMW R 1250 GS 40a 2020 54000 KM
OK, mañana me levantare pronto para una pequeña intervencion al pequeñin!!
