En un principio parecen fallos intermitentes!! tienes algun sintoma o algo no te va bien?
Prueba a borrarlos y a chequear de nuevo a ver si siguen saliendo.
Bueno pues al cambiar el climatronic por uno que se ve en el Rns510 me da estos fallos.
¿sabeis como puedo solucionarlos?
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01006
ROD: N/A
No ASAM data available for this controller:"EV_Climatronic" .
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000005159554
Coding: E7828F0700041A00470A00000F000000000B5D435C00010000 0000000000
Shop #: WSC 00028 028 00001
Part No: 3C1 955 419 A
Component: Wischer 030807 003 0205
Coding: 00046997
Shop #: WSC 00028
Part No: 1K0 955 559 AF
Component: RLS 210907 046 0204
Coding: 00407853
Shop #: WSC 00028
1 Fault Found
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 58
Mileage: 42665 km
Time Indication: 0
Date: 2009.12.22
Time: 11:40:00
Freeze Frame:
OFF
Voltage: 11.85 V
OFF
ON
OFF
OFF
OFF
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P079030450
Coding: FD817F0E4002021002
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 58
Mileage: 42665 km
Time Indication: 0
Date: 2009.12.22
Time: 11:40:57
Address 46: Central Conv. Labels: Redir Fail!
Part No SW: 3C0 959 799 F HW: 3C0 959 799 F
Component: 01 KESSY PQ46 R 070 0225
Revision: 00070000 Serial number: VWZCZ000000000
Coding: 01910A0001C6CE7630029E1F70004FCE50780003242480
ASAM Dataset: ------------------------- ------
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Component: Innenraumueberw.004 0611
1 Fault Found
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 58
Mileage: 42665 km
Time Indication: 0
Date: 2009.12.22
Time: 11:40:59
Passat Highline 2.0 TDI 140cv DSG, Rojo Tornado, Interior Antracita/negro/antracita, Safety Plus y Passat Tech, solarcheck, retrovisores cromados, pedales de aluminio, reposapies del phaeton, RNS 510.
Octavia 2 TDI 140CV BKD: Centralita 30b,Tempomat,Boton Clima, DRL Antiniebla 40%; Luces Americanas,Luces de Giro,5 Luces Freno,2ª Luz Antiniebla ,Navegador Colombus,Confort-Leaving Home,Junta EGR 9mm,Cuadro Maxidot RS,Faros Lupa Scout, Llantas 16", Polar FIS + Advance 350.000 km
No tendras que dar de alta el rns en la gateway?
Como ya te han dicho, son fallos intermitentes.
El clima tiene un positivo fijo, que en cuanto lo desconectas da fallo, a pesar de que este el coche completamente apagado, asi que no te preocupes que es normal.
Salu2
Pues los he borrado y en principio solo me falat el primero que no hay manera
Revision: 00003001
Coding: 0000000000
ROD: N/A
estaba contestando Jurjito cuando escribiste el post.
¿Este fallo sera de una codificacion del clima?
Última edición por valle1; 22/12/2009 a las 13:57
Juanma, eso no es un fallo.
Lo único que te dice ahí es que no ha podido encontrar el fichero EV_Climatronic en la carpeta de labels UDS_EV
¿Tienes la versión 812.4?
De este Sólo usuarios registrados pueden ver links. Por favor, regístrate en el foro haciendo click AQUI., busca en la carpeta UDS_EV (creo que se llama así) el fichero EV_Climatronic y lo pones en la correspondiente carpeta de tu VAG-COM. Así ya debería cogerte la label para la unidad del climatronic nueva que has puesto
Pues nada Pablo ni cambiando lo que me dices.
Lo intento borrar y no me deja, aparte sale en el scan del vagcom en letras rojas
Última edición por valle1; 22/12/2009 a las 20:01
