Dinos de que coche se trata, y mira en los bloques de medida, haz un captura de pantalla a todos los bloques de medicion de engine, como se explica aqui:
18000/P1592/005522 - Altitude Sensor / Boost Pressure Sensor: Implausible Correlation
Possible Symptoms
Possible Causes
- Malfunction Indicator Light (MIL) active
- Limp Mode active
Possible Solutions
- Wiring from/to Boost Pressure Sensor (G31) faulty
- Ground Spots corroded
- Boost Pressure Sensor (G31) faulty
Special Notes
- Check Wiring from/to Boost Pressure Sensor (G31)
- Check Ground Spots for Corrosion
- Check Boost Pressure Sensor (G31)
- When found in 2.0l TDI-PPD (BMN), check TSB/TPL's first.
- Possible Causes: Software Issue, High Resistance in Engine Wiring Harness, Ground Spots corroded
- Possible Solutions: Check/Update Engine Control Module Software, Check Wiring from/to Boost Pressure Sensor (G31), Check Ground Spots for Corrosion
