XYLEN2 (13/06/2012)
En un cordoba que tube se me quemo un fusible que va en la misma bateria de 30 amperios tube que cambiar toda la caja de fusibles echale un vistazo por si las moscas
XYLEN2 (13/06/2012)
Bueno después de hacerle yo con mi vagcom (la anterior diagnosis la hizo en un taller) me salen los siguientes errores.
VCDS Version: Release 908.0
Data version: 20090911
Monday,11,June,2012,17:28:24:13314
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: VSSZZZ1PZ7R027195 Mileage: 117360km/72924miles
00-Steering Angle Sensor -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LK HW: 03G 906 021 AN
Component: R4 1,9L EDC 000SG 9249
Revision: --H05--- Serial number: SEZ7Z0F3591463
Coding: 0050071
Shop #: WSC 06325 000 00000
1 Fault Found:
005716 - Please check DTC Memory of Instrument Cluster
P1654 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 117245 km
Time Indication: 0
Date: 2000.00.00
Time: 13:11:14
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Temperature: 24.3°C
Temperature: 28.8°C
Temperature: 20.7°C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06441 785 00200
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 K
Component: Climatic PQ35 011 0201
Shop #: WSC 00000 000 00000
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004290654
Coding: A0880F2F00041000001D00000000000000017B075C
Shop #: WSC 01742 444 12345
Part No: 1P0 955 119 B
Component: Wischer 081007 022 0601
Coding: 00056208
Shop #: WSC 01742
1 Fault Found:
00926 - Terminal 30
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 157
Mileage: 117367 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 5.00 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R3 AIRBAG VW8 028 2522
Revision: 10028000 Serial number: 003B0PF81HC6
Coding: 0021043
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BB HW: 1K0 953 549 BB
Component: Lenksäulenmodul 636 0070
Coding: 0000002
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 804 C
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002101
Shop #: WSC 05572 843 13298
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
010 - Open or Short to Plus
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 310010680187FE
Coding: 3D0F034007000202
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 F HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 31008001 Serial number: 00000018279107
Coding: 0000048
Shop #: WSC 03263 843 82395
2 Faults Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 117
Mileage: 48978 km
Time Indication: 0
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Reset counter: 157
Mileage: 48978 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.077 H07 1806
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000CC7F000F0F484B012004CC
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 F HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 31008001 Serial number: 00000029979013
Coding: 0000048
2 Faults Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Freeze Frame:
Fault Priority: 3
Reset counter: 117
Mileage: 48978 km
Time Indication: 0
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Freeze Frame:
Fault Priority: 3
Reset counter: 157
Mileage: 48978 km
Time Indication: 0
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0006
Coding: 0020414
Le he dicho que cambie el sensor exterior y veremos como responde la cosa.
Un Saludo chicos!!!
SEAT Toledo TDI 90cv By Bnd Unlimited
Repro Dual Hard y Eco
te dije que siempre es necesaria una Diagnosis, y ya ves que no me equivoco..consulta los fallos registrados en el modulo del cuadro, pero me temo que sera la indicación del sensor de temperatura exterior. también te marca fallo del Terminal 30 que este se sitúa en los fusibles de la batería, y esta conectado a positivo de la misma, y también puede influir en tu problema, di que lo revisen también. salu2
XYLEN2 (13/06/2012)
Buenas chicos, se ha cambiado el sensor de temperatura exterior y se soluciono el problema.
Muchas Gracias a todos y se puede cerrar el tema.
buen tajo... simpre hay que hcer mas de un dagnostico ....
TDI POWER... :ganador::mrgreen::demonio:
Pero, mejor hacerlo uno mismo, que las maquinas multimarca muchas veces no terminan de ir todo lo bien que deberían.
Un Saludo
