Página 1 de 2 12 ÚltimoÚltimo
Resultados 1 al 10 de 13
Tema: Golf 6 se me encienden 3 testigos
    Nº de Usuario: 3838
    23-mar-2010
    europa
    Golf VI sport tdi 110cv
    Agradecido 3 veces en 1 mensaje
    Predeterminado Golf 6 se me encienden 3 testigos
    Solucionado.
    Bueno lo dicho seme han encendido tres testigos: el del freno de mano
    el del ABS
    el del ESP
    La semana pasada se cambio la batería
    La maquina es un golf 6 2.0 TDI 110cv
    Saludos y gracias
    Sunday,12,April,2020,18:11:44:13314
    VCDS Version: Release 908.0
    Data version: 20090911
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 MC HW: 03L 906 022 G
    Component: R4 2.0l TDI G000SG 9979
    Revision: 13H01--- Serial number:
    Coding: 0000071
    Shop #: WSC 01357 011 00200
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (-----) Labels: None
    Part No SW: 1K0 907 379 CE HW: 1K0 907 379 AE
    Component: ESP MK60EC1 H35 0120
    Revision: 00H35001
    Coding: 113B200D09250000881004E9901A00423100
    Shop #: WSC 61759 001 1048576
    1 Fault Found:
    16352 - Control Module - Electrical Error
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 48
    Mileage: 130757 km
    Time Indication: 0
    Date: 2127.14.31
    Time: 09:45:37
    Freeze Frame:
    Count: 0
    Count: 32768
    Count: 12800
    Count: 96
    Count: 50996
    Count: 521
    Count: 0
    Count: 0
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 5K0 907 044 AJ HW: 5K0 907 044 AJ
    Component: Climatronic 130 0303
    Revision: 00002001
    Coding: 0000000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Climatronic A01001
    ROD: EV_Climatronic_VW36.rod
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 086 HW: 1K0 937 086
    Component: BCM PQ35 M 020 0358
    Revision: 00020000
    Coding: 40180A3A98251AC040080080140081E445510088536D896064 8000000000
    Part No: 1K1 955 119 E
    Component: Wischer 30100 21 0501
    Coding: 009795
    Part No: 1K0 955 559 AH
    Component: RLS 181108 05 54 0402
    Coding: 0330AD
    4 Faults Found:
    00978 - Lamp for Low Beam; Left (M29)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 1
    Fault Frequency: 6
    Reset counter: 74
    Mileage: 130562 km
    Time Indication: 0
    Date: 2127.14.03
    Time: 13:29:22
    Freeze Frame:
    Term 15 On
    Voltage: 13.95 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 74
    Mileage: 128685 km
    Time Indication: 0
    Date: 2124.14.19
    Time: 13:18:28
    Freeze Frame:
    Term 15 On
    Voltage: 13.85 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    01520 - Rain and Light Recognition Sensor (G397)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 83
    Mileage: 130667 km
    Time Indication: 0
    Date: 2127.14.27
    Time: 15:04:42
    Freeze Frame:
    Term 15 On
    Voltage: 10.90 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 129326 km
    Time Indication: 0
    Date: 2125.14.22
    Time: 05:54:06
    Freeze Frame:
    Term 15 On
    Voltage: 14.10 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
    Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
    Component: PARKHILFE 8K H01 0012
    Revision: -------- Serial number: 12531516103835
    Coding: 100001
    Shop #: WSC 01742 444 12345
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 HW: 5K0 959 655
    Component: AirbagVW10 022 0507
    Serial number: 003C2D05K9M0
    Coding: 00003135
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
    Component: J0527 055 0111
    Coding: 0000732
    Part No: 3C8 959 537 B
    Component: E221__MFL-TAP H4ÿ 0021
    Coding: 00000226
    Shop #: WSC 00000
    1 Fault Found:
    01426 - Controls in Steering Wheel (E221)
    004 - No Signal/Communication - Intermittent
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K0 920 870 C HW: 5K0 920 870 C
    Component: KOMBI H21 0029
    Serial number: 00000000000000
    Coding: 170B00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 S HW: 1K0 907 951
    Component: J533 Gateway H07 0071
    Revision: H07 01 Serial number: 271008F2000732
    Coding: E9A07F06400612000002
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Component: IMMO H21 0029
    Serial number:
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    Address 2E: Media Player 3 (J650) Labels: None
    Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
    Component: SG EXT.PLAYER H13 0084
    Revision: A1001003 Serial number: 7667312817
    Coding: 010000
    Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
    Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
    Component: RNS-MID H06 5238
    Revision: AB001001 Serial number: VWZ6Z7K8069131
    Coding: 04000400040000810000
    ASAM Dataset: ------------------------- ------
    Part No: 1T0 919 859 B
    Component: EU West V16 8536
    1 Fault Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 90
    Mileage: 99672 km
    Time Indication: 0
    Date: 2101.14.08
    Time: 10:02:10
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 1K0 959 701 AN HW: 1K0 959 701 AN
    Component: Tuer-SG 008 2015
    Coding: 0004278
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 69 2301
    Revision: 00H15000
    Shop #: WSC 01324 785 00200
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 1K0 959 702 AG HW: 1K0 959 702 AG
    Component: Tuer-SG 008 2033
    Coding: 0004534
    Address 56: Radio (J0506) Labels: 1T0-035-680.lbl
    Shop #:
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 90
    Mileage: 99672 km
    Time Indication: 0
    Date: 2101.14.08
    Time: 10:02:10
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
    Component: Tuer-SG 007 2009
    Coding: 0000144
    Shop #: WSC 01357 011 1012552
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 AL HW: 1K0 959 704 AL
    Coding: 0000144
    Address 77: Telephone Labels: 5P0-862-335.lbl
    Part No SW: 1Z0 035 729 E HW: 1Z0 035 729 E
    Component: FSE_2P8x H40 0190
    Revision: 00000000 Serial number: 00000005163101
    Coding: 0010455
    Sunday,12,April,2020,18:17:01:13314
    Chassis Type: 1K0
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
    VIN:
    Coding: 0000071
    Revision: 00H35001
    1 Fault Found:
    014 - Defective
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 48
    Mileage: 130757 km
    Time Indication: 0
    Date: 2127.14.31
    Time: 09:45:37
    Freeze Frame:
    Count: 0
    Count: 32768
    Count: 12800
    Count: 96
    Count: 50996
    Count: 521
    Count: 0
    Count: 0
    Revision: 00002001
    Coding: 0000000000
    Revision: 00020000
    Coding: 009795
    Coding: 0330AD
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 6
    Reset counter: 74
    Mileage: 130562 km
    Time Indication: 0
    Date: 2127.14.03
    Time: 13:29:22
    Freeze Frame:
    Term 15 On
    Voltage: 13.95 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 74
    Mileage: 128685 km
    Time Indication: 0
    Date: 2124.14.19
    Time: 13:18:28
    Freeze Frame:
    Term 15 On
    Voltage: 13.85 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 83
    Mileage: 130667 km
    Time Indication: 0
    Date: 2127.14.27
    Time: 15:04:42
    Freeze Frame:
    Term 15 On
    Voltage: 10.90 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 129326 km
    Time Indication: 0
    Date: 2125.14.22
    Time: 05:54:06
    Freeze Frame:
    Term 15 On
    Voltage: 14.10 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Coding: 100001
    Coding: 00003135
    Coding: 0000732
    Coding: 00000226
    Shop #: WSC 00000
    1 Fault Found:
    Coding: 170B00
    Serial number:
    Coding: 010000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 90
    Mileage: 99672 km
    Time Indication: 0
    Date: 2101.14.08
    Time: 10:02:10
    Coding: 0004278
    Revision: 00H15000
    Coding: 0004534
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 90
    Mileage: 99672 km
    Time Indication: 0
    Date: 2101.14.08
    Time: 10:02:10
    Coding: 0000144
    Coding: 0000144
    Coding: 0010455
    Última edición por jaiak; 14/04/2020 a las 15:14 Razón: poner la dianosis
    Nº de Usuario: 14225
    19-may-2012
    Almeria
    seat leon 2 2.0 tdi 140cv
    Agradecido 690 veces en 633 mensajes.
    Sin diagnosis, poco podemos decirte.
  3. El Siguiente Usuario Agradeció a José R Por Este Mensaje:
    jaiak (12/04/2020)
    Nº de Usuario: 3838
    23-mar-2010
    europa
    no tengo garaje y esta lloviendo cuando escampe un ratico hago el escáner
  5. #4
    Avatar de golf_dsg
    Nº de Usuario: 7273
    31-ene-2011
    en el coche
    Golf V 2.0 tdi dsg,BKD
    Agradecido 18 veces en 16 mensajes.
    Una diagnosis para poder averiguar por donde vienen los fallos.
  6. #5
    Avatar de Azul Mauricio
    Nº de Usuario: 15687
    19-ago-2012
    Al norte de Madrid city
    El coche ha rodado algo desde que cambiaste la bateria?
    Quizá solo necesita eso para que se quiten los errores. Se quitan solos cuando circulas unos metros.
  7. #6
    Avatar de golf_dsg
    Nº de Usuario: 7273
    31-ene-2011
    en el coche
    Muy cierto compañero, ami golf v cuando se la desconectas y conectas te salen el del esp y abs, con girar el volante y andar un poco se borra ya todo.
  8. #7
    Nº de Usuario: 3838
    23-mar-2010
    europa
    perdonar aki esta :
    Coding: 0000071
    Revision: 00H35001
    1 Fault Found:
    014 - Defective
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 48
    Mileage: 130757 km
    Time Indication: 0
    Date: 2127.14.31
    Time: 09:45:37
    Freeze Frame:
    Count: 0
    Count: 32768
    Count: 12800
    Count: 96
    Count: 50996
    Count: 521
    Count: 0
    Count: 0
    Revision: 00002001
    Coding: 0000000000
    Revision: 00020000
    Coding: 009795
    Coding: 0330AD
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 6
    Reset counter: 74
    Mileage: 130562 km
    Time Indication: 0
    Date: 2127.14.03
    Time: 13:29:22
    Freeze Frame:
    Term 15 On
    Voltage: 13.95 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 74
    Mileage: 128685 km
    Time Indication: 0
    Date: 2124.14.19
    Time: 13:18:28
    Freeze Frame:
    Term 15 On
    Voltage: 13.85 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 83
    Mileage: 130667 km
    Time Indication: 0
    Date: 2127.14.27
    Time: 15:04:42
    Freeze Frame:
    Term 15 On
    Voltage: 10.90 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 129326 km
    Time Indication: 0
    Date: 2125.14.22
    Time: 05:54:06
    Freeze Frame:
    Term 15 On
    Voltage: 14.10 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Coding: 100001
    Coding: 00003135
    Coding: 0000732
    Coding: 00000226
    Shop #: WSC 00000
    1 Fault Found:
    Coding: 170B00
    Serial number:
    Coding: 010000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 90
    Mileage: 99672 km
    Time Indication: 0
    Date: 2101.14.08
    Time: 10:02:10
    Coding: 0004278
    Revision: 00H15000
    Coding: 0004534
    Shop #:
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 90
    Mileage: 99672 km
    Time Indication: 0
    Date: 2101.14.08
    Time: 10:02:10
    Coding: 0000144
    Coding: 0000144
    Coding: 0010455
    Chassis Type: 1K0
    VIN:
    Coding: 0000071
    Revision: 00H35001
    1 Fault Found:
    014 - Defective
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 48
    Mileage: 130757 km
    Time Indication: 0
    Date: 2127.14.31
    Time: 09:45:37
    Freeze Frame:
    Count: 0
    Count: 32768
    Count: 12800
    Count: 96
    Count: 50996
    Count: 521
    Count: 0
    Count: 0
    Revision: 00002001
    Coding: 0000000000
    Revision: 00020000
    Coding: 009795
    Coding: 0330AD
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 6
    Reset counter: 74
    Mileage: 130562 km
    Time Indication: 0
    Date: 2127.14.03
    Time: 13:29:22
    Freeze Frame:
    Term 15 On
    Voltage: 13.95 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 74
    Mileage: 128685 km
    Time Indication: 0
    Date: 2124.14.19
    Time: 13:18:28
    Freeze Frame:
    Term 15 On
    Voltage: 13.85 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 83
    Mileage: 130667 km
    Time Indication: 0
    Date: 2127.14.27
    Time: 15:04:42
    Freeze Frame:
    Term 15 On
    Voltage: 10.90 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 129326 km
    Time Indication: 0
    Date: 2125.14.22
    Time: 05:54:06
    Freeze Frame:
    Term 15 On
    Voltage: 14.10 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Coding: 100001
    Coding: 00003135
    Coding: 0000732
    Coding: 00000226
    Shop #: WSC 00000
    1 Fault Found:
    Coding: 170B00
    Serial number:
    Coding: 010000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 90
    Mileage: 99672 km
    Time Indication: 0
    Date: 2101.14.08
    Time: 10:02:10
    Coding: 0004278
    Revision: 00H15000
    Coding: 0004534
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 90
    Mileage: 99672 km
    Time Indication: 0
    Date: 2101.14.08
    Time: 10:02:10
    Coding: 0000144
    Coding: 0000144
    Coding: 0010455
  9. #8
    No comentas si has borrado o no.
    Esos errores suelen salir cuando sacas batería.
    Al borrar los errores debería bastar. Si persisten es para preocuparse. Haz la prueba, dale a ''clear DTC''
  10. #9
    Nº de Usuario: 3838
    23-mar-2010
    europa
    lo he borrado y siguen
    no me asustes , que crees .
    intentare borrarlos mañana .
    me paso al de 3 días del cambio de batería
  11. #10
    19-may-2012
    Almeria
    Yo te diría que esas averias no están borradas, ya que por ejemplo el módulo de la radio tiene una averia registrada con 99.000kms. Borra las averías y hacer autoscan y lo pones por aquí.
    Había una campaña para cambiar el módulo del abs, no sé si afectará a tu coche. La hacían en los leones 2 reestiling.
