Entro con el vagcom, en Xenon Range y tengo 3 fallos, luego si me da tiempo los copio para ponerlos aqui. Pues resulta que le doi a borrar fallos, pero no pasan 2 segundos y ya vuelven a salir esos 3 fallos. Asi todo el rato.
Otra cosa, es que quiero regular la altura de esta manera que me comentarais, pero no me deja.
Coding
• 0000001 = VW Touran (1T) Front-Wheel-Drive (FWD)
• 0000002 = VW Touran (1T) All-Wheel-Drive (AWD)
• 0000003 = VW Golf/Jetta (1K/5M) Front-Wheel-Drive (FWD)
• 0000004 = VW Golf/Jetta (1K/5M) All-Wheel-Drive (AWD)
• 0000007 = Skoda Octavia (1Z) Front-Wheel-Drive (FWD)
• 0000009 = Seat Altea/Toledo (5P) / Leon (1P)
Adaptation
Basic Setting
Headlight Adjustment
[Select]
[55 - Xenon Range]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
• The meas. block field now shows "Wait" and should switch to "Adjust Headlights" then (this may take up to 10 seconds).
• Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target.
[ON/OFF/Next]
The adjustment should now be learned.
[Done, Go Back]
[Close Controller, Go Back - 06]
Espero vuestra ayuda. Saludos y gracias
