No consigo entender los fallos del vcds!! Ayuda!
Buenos días compañeros,
Tengo un Audi a5 2009 2.0tdi, ayer perdío fuerza el motor y hoy no consigo arrancarlo. he metido el cable VCDS 12.12, pero no entiendo los fallos que me salen. Sería alguien tan amable de indicarme donde esta el fallo. Gracias.
adjunto;
Chassis Type: 8T (8T0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 20 42 46 52 53 55 56 5F 62
72
VIN: WAUZZZ8T8AA016021 Mileage: 226660km/140839miles
01-Engine -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (FAHB) Labels: None
Revision: 25H21-(-
Coding: 1A1940122344060800004920204939
ASAM Dataset: EV_ECM70TDI03I906022KR A02008
ROD: N/A
VCID: 55A167DF34F48DB6975-8000
No ASAM data for: "EV_ECM70TDI03I906022KR" (AU48)
7 Faults Found:
5211 - ROD - Unknown Error Code
- 00 [101]
Not Confirmed - Tested Since Memory Clear
5209 - ROD - Unknown Error Code
- 00 [101]
5229 - ROD - Unknown Error Code
- 00 [100]
Intermittent - Not Confirmed - Tested Since Memory Clear
4463 - ROD - Unknown Error Code
- 00 [101]
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 226669 km
Date: 2019.08.15
Time: 14:37:00
10065 - ROD - Unknown Error Code
- 00 [100]
332922 - ROD - Unknown Error Code
- 00 [101]
7934 - ROD - Unknown Error Code
- 00 [101]
Readiness: 0000 0000
