01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 056 AA HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 2898
Revision: --H09--- Serial number: SEX7Z0I231A0BW
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 66C9A841517CEC9
1 Fault Found:
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Freeze Frame:
Fault Status: 01110000
Fault Priority: 3
Fault Frequency: 1
Mileage: 43919 km
Time Indication: 0
Date: 2000.00.00
Time: 06:30:30
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00101100
Temperature: 15.3°C
Bin. Bits: 00110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 04941 000 00000
VCID: 74EDC209D7A00E9
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 1048575 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 0
Count: 4608
Count: 195
Count: 44032
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
VCID: 2D5B176DB40A1F1
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000006053985
Coding: A1880FAF0004100F431D00002D00000000017F075C40000C00 0000000000
Shop #: WSC 43256 213 42544
VCID: 336F0115522E491
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 170209 022 0601
Coding: 00056208
Shop #: WSC 43256
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A01 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP4BBG9F
Coding: 0012337
Shop #: WSC 06402 785 00200
VCID: 3B7F29357A7E811
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 855 0111
Coding: 0000134
VCID: 7AF1EC3135C4789
Part No: XXXXXXXXXXX
Component: E0221 001 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 840 C
Component: KOMBIINSTRUMENT VO3 0522
Coding: 0002101
Shop #: WSC 00599 843 01477
VCID: 2B5F19758A1E111
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K0921600D3
Coding: E9807F06000202000202
VCID: 377735054656A51
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 35
Reset counter: 22
Mileage: 43621 km
Time Indication: 0
Date: 2000.00.00
Time: 23:39:35
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 43621 km
Time Indication: 0
Date: 2000.00.00
Time: 23:39:38
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0522
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1517
Revision: 71009005 Serial number: 00000759389119
Coding: 0004272
VCID: 40855ED91398E29
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 0 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.065 H08 1901
VCID: 356B3F0D5C5A571
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 988008005283CC7F00068F0F60084F86107C80
VCID: 830F11D5C20EB91
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 43256
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 29
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1517
Revision: 71009005 Serial number: 00000500789128
Coding: 0004272
VCID: 41835BDD1892EB1
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 0 km
Time Indication: 0
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0007
Coding: 0040424
2 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit - Intermittent
00871 - Bass Speaker Front Right (R23)
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000003810852
Coding: 0000144
VCID: 74EDC20917A00E9
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000003806659
Coding: 0000144
VCID: 75EBFF0D1CDA171
