Hola a Todos!!
Espero no os importe que os consulte sobre la lectura que hice del Touareg. No se que significa eso de Redir Fail! y que al parecer no hay errores en ningún módulo o no deja conectarse a 4 módulos:
Código:
VCDS Version: Release 11.11.0Data version: 20111111
Friday,06,September,2013,17:23:35:37412
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGXXXXXXXXXXXXXX Mileage: 93000km/57787miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 7L0 907 401 D HW: 7L0 907 401 D
Component: 3.0L V6TDI G000AG 0030
Revision: --H04--- Serial number: VWX3Z0G1572045
Coding: 0011775
Shop #: WSC 29084 141 173640
VCID: 2C5D75148C1028E
Part No: 7L0 907 401 D
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FA HW: 09D 927 750 FA
Component: AL 750 6A 0992
Revision: 00H61000 Serial number:
Coding: 0004456
Shop #: WSC 31414 790 00001
VCID: 72E1AB6C6EB43EE
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 K HW: 7L0 907 379 K
Component: ESP ALLRAD MK25E1 0302
Revision: 00H53001
Coding: 0004482
VCID: 418334A01C92D56
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 B HW: 5WK 485 04
Component: Kessy 6840
Revision: 68406418 Serial number: VWX3Z0G1572045
Coding: 0000232
VCID: 285589049FE804E
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 AE
Component: CLIMAtronic R/L 4326
Coding: 0000030
VCID: 73EFAE6816AE376
Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AA HW: 7L6 937 049 AA
Component: J519 1800
Serial number: --------------
Coding: 600004003B321E000000000000000000
VCID: 7BFF86483EFE7F6
No Faults Found
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234 2Z VW8T 0250
Revision: 92011025 Serial number: 0039P000J03G
Coding: 0012890
VCID: FAF1034CB1C4C6E
No Faults Found
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 F
Component: Lenksaeulenmodul 3501
Coding: 0010011
VCID: 42813BAC1994CEE
No Faults Found
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 890 C HW: 7L6 920 890 C
Component: J285 KOMBI-INST. 9533
Revision: KHH06X62
Coding: 0007101
Shop #: WSC 29084 141 66979
VCID: 387559444B4894E
Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 890 C
Component: J533 GW-K-CAN TP20 9533
Coding: 7FE2E7DBC9076002
VCID: F0E52164E3B88CE
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No SW: 7L6 919 879 B HW: 7L6 919 879 B
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1439802T03VK02
Shop #: WSC 00000 000 00000
VCID: 468927BC31BCF2E
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0119
VCID: 7F0772582DE6636
Address 34: Level Control Labels: None
Part No: 7L0 907 553 G
Component: LUFTFDR.-CDC- 3C3P1 3112
Coding: 0015521
VCID: 37775A7842569B6
Address 46: Central Conv. Labels: None
Part No: 7L6 959 933
Component: 12 HSG 7124
Coding: 0000085
VCID: FF07F258ADE6E36
Part No: 7L0 959 701 N
Component: Tuersteuergeraet FS 6302
Part No: 7L0 959 702 N
Component: Tuersteuergeraet BF 6302
Part No: 7L6 959 703
Component: Tuersteuergeraet HL 0202
Part No: 7L6 959 704
Component: Tuersteuergeraet HR 0202
Address 55: Xenon Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 A HW: 7L6 907 357 A
Component: AFS-Steuergeraet X014
Revision: H01 Serial number:
Coding: 1288195
VCID: 39735C4074428D6
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l X008
Coding: 00000019
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul r X008
Coding: 00000019
Address 68: Wiper Electr. Labels: None
Part No: 7L6 955 119
Component: J400__ Front Wiper 5101
Coding: 0000341
VCID: F7F71A7886D6DB6
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 210708 046 0204
Coding: 00208933
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000001
VCID: 387559444F4894E
Address 6D: Trunk Elect. Labels: None
Part No SW: 7L6 959 107 HW: 7L6 959 107
Component: J605 HECKKLAPPE 1110
Revision: --H05--- Serial number: --------009645
Coding: 0022110
VCID: F8F519448FC8D4E
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
