antonio 25th (16/02/2015)
hoy le hemos pasado autoscan mi primo que es forero tambien(Antonio25th) y yo y aqui os dejo los resultados por si nos podeis echar una mano, un saludo y gracias de antemano.
golf 4 ASV (antonio25th)
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 248790km/154590miles
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 012 AP
Component: 1,9l R4 EDC 0400SG 2807
Coding: 00002
Shop #: WSC 00046
VCID: 5EB378F3DAC24EEEC6F-49D8
4 Faults Found:
17664 - Engine Coolant Temp Sensor (G62)
P1256 - 35-10 - Open or Short to Plus - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
17569 - Manifold Temp Sensor (G72)
P1161 - 35-00 - Open or Short to Plus
17564 - Manifold Pressure Sensor (G71)
P1156 - 35-00 - Open/Short to Ground
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 00046 615 1234567
VCID: 2A5BE423860AF24EEA7-5072
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 1.0.0
Coding: 01000
Shop #: WSC 00046
VCID: 2149030FAB3C3116BBD-5072
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 27 AIRBAG VW5 01 0006
Coding: 12855
Shop #: WSC 00046
VCID: 3561C75F0FB4ADB6775-4A3A
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 825 B
Component: KOMBI+WEGFAHRS. BOO V10
Coding: 01122
Shop #: WSC 00046
VCID: 275D1D17C518CF26F59-5000
Subsystem 1 - Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0A3022861
Ident.-Nr. WEGFAHRS.:VWZ6Z0A3022861
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00046
VCID: F0EFB64BB056489EE43-5000
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 4H Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 00046
VCID: 8407EA9B94EE443E30B-49D8
Subsystem 1 - Part No: 1J1959801C
Component: 4H Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 4H Tõrsteuerger. BF0002r
3 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00--
Audi a3 8p Bkd
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000005929164
Coding: FF8A5F078214100000000000000000000008EE175A0600
Shop #: WSC 06314 123 08192
VCID: 408FA68B1376181ED43-8015
Subsystem 1 - Part No: 8P1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 06314
7 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 6
Mileage: 206822 km
Time Indication: 0
Date: 2015.02.10
Time: 12:54:00
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 6
Mileage: 206822 km
Time Indication: 0
Date: 2015.02.10
Time: 13:29:00
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Status: 00111010
Fault Priority: 1
Fault Frequency: 2
Reset counter: 6
Mileage: 205266 km
Time Indication: 0
Date: 2014.12.26
Time: 13:00:00
Freeze Frame:
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 6
Mileage: 205266 km
Time Indication: 0
Date: 2014.12.26
Time: 13:00:00
Freeze Frame:
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 254
Reset counter: 235
Mileage: 205266 km
Time Indication: 0
Date: 2014.12.26
Time: 12:55:00
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
OFF
02896 - Control Circuit for LED Module for DRL and Parking Light; Left
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 252
Reset counter: 20
Mileage: 205266 km
Time Indication: 0
Date: 2014.12.26
Time: 12:57:00
Freeze Frame:
OFF
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
Freeze Frame:
Fault Priority: 2
Reset counter: 20
Mileage: 205266 km
Time Indication: 0
Date: 2014.12.26
Time: 12:57:00
Freeze Frame:
OFF
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H12 3720
Revision: 91H12372 Serial number: 0037W002F43N
Coding: 0070612
Shop #: WSC 06314 000 00000
VCID: 479DBD9736582F26159-8012
Subsystem 1 - Serial number: 63328RB4015C911AH
Subsystem 2 - Serial number: 63428RB4015CB334I
Subsystem 3 - Serial number: 63528RB4015C916DR
Subsystem 4 - Serial number: 63628RB4015CA5DA.
Subsystem 5 - Serial number: 63729RB401657535F
Subsystem 6 - Serial number: 63829RB401657536H
1 Fault Found:
01312 - Powertrain Data Bus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H34 0070
Coding: 0002012
VCID: 4189A38F187C1116DBD-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
1 Fault Found:
01304 - Radio
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 G HW: 1K0 907 951
Component: J533__Gateway H10 0140
Revision: H10 Serial number: 300010661582C4
Coding: 7D0F0B4207000100
VCID: 2B55E1278AF0EB46111-807E
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Reset counter: 235
Mileage: 100877 km
Time Indication: 0
Date: 2010.08.13
Esas averías se han borrado en ambos coches? o según acabo el AutoScan se colgaron directamente sin borrar? si no están borradas, te aconsejo borrar las mismas, salir a dar una gran vuelta, y pasar de nuevo un AutoScan, para determinar si esas averías son reales o sólo estaban pendientes de borrarse. Es importante saber esto para ayudarte. Salu2
Yo se que el sensor temperatura del refrigerante lo tengo mal...las otras averias no se cuales son...
El cacharro, en cuestión...Sólo usuarios registrados pueden ver links. Por favor, regístrate en el foro haciendo click AQUI.
Código:17664 - Engine Coolant Temp Sensor (G62) P1256 - 35-10 - Open or Short to Plus - Intermittent 17978 - Engine Start Blocked by Immobilizer P1570 - 35-00 - 17569 - Manifold Temp Sensor (G72) P1161 - 35-00 - Open or Short to Plus 17564 - Manifold Pressure Sensor (G71) P1156 - 35-00 - Open/Short to Ground
17664 - Sensor de temperatura de refrigerante o cableado.
17978 - Es del inmo, llave no casada, cuadro, o una posible batería baja.
17569 y 17564 - Es el MAP, el sensor de presión, revisa el cableado, o bien que esté defectuoso (yo cuando desmonto el tubo siempre se me olvida conectarlo y se me queda en limp mode).
Código:01274 - Air Flow Flap Positioning Motor (V71)Código:37-10 - Faulty - Intermittent
Es el servomotor de la trampilla de recirculación de aire, del climatizador.
Código:00953 - Interior Light Time limit 25-10 - Unknown Switch Condition - Intermittent 00943 - Heated Exterior Mirror; Driver Side (Z4) 35-00 - - 00944 - Heated Exterior Mirror; Passenger Side (Z5) 35-00--
00953 - Es de la luz de apertura de puertas, hay que revisar cableado, lámparas, conectores, o interruptores de las puertas.
00943 y 00944 - son los espejos eléctricos que se les han fundido las resistencias, normalmente sucede por llevar el regulador de los espejos en la posición central y se queman con el tiempo por ir siempre activos.
Código:01312 - Powertrain Data Bus 004 - No Signal/Communication - Intermittent
Tendrás la luz de malfuncion en el cuadro, o el inmo ha bloqueado un arranque, según lo que dice la pág. de ross-tech hay que comprobar cableado o conexiones del bus de datos, o modulo de control. Puede que tenga relación con el otro error de inmo que tenías.
Última edición por JoeDalton; 16/02/2015 a las 21:51
Que es el MAP?? Por otra parte, no tengo testigo ninguno en el cuadro...
Módulo control es igual a centralita confort??
Última edición por antonio 25th; 16/02/2015 a las 23:30
El MAP es el sensor que lleva a la salida del intercooler, el que coincide justo donde esta el tanque del líquido del limpia.
Y si se podría decir que la centralita /modulo confort es lo mismo.
SEAT EXEO TDI 143 CV REPRO
antonio 25th (17/02/2015)
Así rápidamente, porque no me puedo explayar mucho:
Código:01496 - Bulb for Fog-Lamps; Left (L22) 010 - Open or Short to Plus - Intermittent 01500 - Bulb for Fog-Lamps; Right (L23) 010 - Open or Short to Plus - Intermittent 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus - Intermittent 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus - Intermittent 01520 - Rain and Light Recognition Sensor (G397) 008 - Implausible Signal 02896 - Control Circuit for LED Module for DRL and Parking Light; Left 007 - Short to Ground - Intermittent 02898 - Control Circuit for LED Module for DRL and Parking Light; Right 007 - Short to Ground - Intermittent
Errores en luces antiniebla y luces de cruce, y DLR, o bien lamparas (las 4? + DLR?), cableado, o algo mal codificado
Sensor de lluvia y luz, revisar fusible, cableado del sensor, o que esté mal codificado el módulo.
Yo creo que aquí hay algo mal codificado.
Este es el mismo que tiene antonio 25thCódigo:01312 - Powertrain Data Bus 004 - No Signal/Communication - Intermittent
Supongo que la radio la has cambiado y da error porque sigue codificadaCódigo:01304 - Radio 004 - No Signal/Communication
Última edición por JoeDalton; 17/02/2015 a las 06:57 Razón: Formato
las luces es una desconfiguracion de la central.electronica que me hicieron en la audi en algeciras...me pusieron funciones del audi a3 del 2010 con led y de mas y me pone que no tngo lavafaros y si tengo, un lio de ******* pero ya van bien todas las luces tanto diurnas bixenon antinieblas posicion todas, en cuanto a la radio es que la quite cuando le hice el autoscan por temor a que se me desconfigurara, un saludo y muchas gracias compañeros
