Muy buenas gente, hace unos días me decidí a comprar un cable 12.12.0, siempre he tenido curiosidad. Al grano... tengo el famoso golf V del 2004 BKD 2000 140cv. y bueno como siempre lo tipico... cuesta arrancar en caliente, tiembla en relentin, cabecea y parece que corte en frio... he hecho un auto scan y estos son los fallos que da:
VCDS Version: Release 12.12.0
Data version: 20130910
Tuesday,19,December,2017,23:55:50:62939
Chassis Type: 1K (1K0)
Scan:
01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ4B075003 Mileage: 225450km/140088miles
2 Faults Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Freeze Frame:
RPM: 840 /min
Torque: 72.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.59 V
Bin. Bits:
00001100
Temperature: 10.8°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 840 /min
Torque: 72.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.59 V
Bin. Bits:
00001100
Temperature: 10.8°C
Bin. Bits: 10110000
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
3 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - - - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
000 - -
01274 - Air Flow Flap Positioning Motor (V71)
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
1 Fault Found:
00526 - Brake Light Switch-F
008 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 1K0-909-605.lbl
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status:
01100100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 117
Mileage: 186481 km
Time Indication: 0
Date: 2000.00.00
Time: 17:04:42
01304 - Radio
Freeze Frame:
Fault Status:
01100100
Fault Priority: 2
Reset counter: 117
Mileage: 186481 km
Time Indication: 0
Date: 2000.00.00
Time: 17:04:45
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
1 Fault Found:
01134 - Alarm Horn (H12)
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
End -----------------------------------
También tengo un par de vídeos con los parámetros a relentin de los canales 013, 018, 023 que subiré si alguien lo creé necesario.
GRACIAS DE ANTEMANO.
