Resultados 1 al 10 de 12
Tema: Puerta piloto y aguja temperatura loca
    Nº de Usuario: 79076
    19-feb-2019
    Pamplona
    Passat 3bg highline 1.9 tdi 130cv 2004 avf
    Predeterminado Puerta piloto y aguja temperatura loca
    Muy buenas compañeros:
    Pues después de adquirir un passat 3bg con 132000 kilómetros le he un autoscan con vag com 12.12 y esto es lo que me ha salido
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 KD
    Component: 1,9l R4 EDC 0000SG 4897
    Coding: 00002
    Shop #: WSC 05314
    VCID: 63C54907F1A06306E91-49D8
    WVWZZZ3BZ4E346279 VWZ7Z0D9446838
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 4B0-614-517.lbl
    Part No: 4B0 614 517 G
    Component: ABS/ESP front 3428
    Coding: 04255
    Shop #: WSC 05311
    VCID: 2541171FBF14DD36C75-5072
    Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
    Part No: 3B1 907 044 K
    Component: CLIMATRONIC B5GP 0010
    Coding: 17000
    Shop #: WSC 05311
    VCID: 29591B2FD30CF956E3D-5000
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 C
    Component: 0E AIRBAG VW61 04 0003
    Coding: 12357
    Shop #: WSC 05311
    VCID: 24470A1BB42E243ED0B-5000
    Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
    Part No: 3B0 920 829 A
    Component: KOMBI+WEGFAHRSP VDO V04
    Coding: 05115
    Shop #: WSC 00000
    1 Fault Found:
    01039 - Coolant Temperature Sensor (G2)
    30-10 - Open or Short to Plus - Intermittent
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 05311
    VCID: F0EFB64BB056489EE43-5000
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 B
    Component: 03 Komfortgerát HLO 0004
    Coding: 00259
    Shop #: WSC 05311
    VCID: 3663C05312B2A6AE7EF-4A3A
    Subsystem 1 - Part No: 1C1959801
    Component: 03 Tõrsteuer.FS KLO 0202
    Subsystem 2 - Part No: 1C1959802
    Component: 03 Tõrsteuer.BF KLO 0202
    Subsystem 3 - Part No: 1C0959811
    Component: 03 Tõrsteuer.HL KLO 0202
    Subsystem 4 - Part No: 1C0959812
    Component: 03 Tõrsteuer.HR KLO 0202
    1 Fault Found:
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    27-00 - Implausible Signal
    la aguja de la temperatura motor esta loca, de repente baja, de repente sube a 90.... no se si esta mal el tablero o algo del motor
    luego la puerta del conductor hay veces que se cierra y otras no....
    Por otro lado, no tengo ni idea de mecánica y veo mucho cosas por aquí que no entiendo muy bien...
    el coche era del padre de una amiga de mi moza y esta tal y como salio del concesionario, sin ninguna mod ni nada, algo que poco a poco iré haciendo y sobre todo preguntando mucho....
    me gustaría si podéis que me recomendaras cosas básicas que le puedo hacer yo al coche sin liarla....
    lo primero y principal hacer un backup de como esta el coche... me parece lo mas basico
    el otro día cuando hice el auto scan active el auto lock, algo que ha veces no funciona y creo que es por la cerradura...
    recomendaciones para hacerle al coche, egr con el manual de M0nch0? modificar el angle synchro??? n75??
    seria recomendable comprar algún producto de esos que se echan en el deposito para limpiar el motor o inyectores o esas cosas???
    algo para bajar el consumo??? repro??
    gracias, saludos y perdón por el tostón
    Nº de Usuario: 18377
    03-feb-2013
    malaga
    a simple vista y con lo que comentas,
    tienes un problema en la cerradura del conductor, por suciedad dentro de la cerradura, se suele solventar echandole wd40 a saco.. (pan pa hoy hambre pa mañana...) cambiando o desmontandola y limpiandola.
    sobre lo de la aguja, casi seguro es el sensor de temperatura del agua,
    Que motor es?
    19-feb-2019
    Pamplona
    Cita Iniciado por gavi23 Ver Mensaje
    Que motor es?
    Muy buenas, es un 1.9 tdi 130cv avf de 2004, en principio se va ha hacer cargo el vendedor, va a comprar las piezas que fallan y sustituir
    Gracias y saludos
    19-feb-2019
    Pamplona
    Ahora no se me abre ni la puerta del maletero, ni con el mando ni desde dentro ni con la llave... el caso es que hace el ruido normal al apretar el puslador de abrir del porton encima de la matricula, pero nada de nada....tiene palanca anti secuestro???
    Passat 1.9 TDI 130cv Highline AVF 2004
    Nº de Usuario: 59087
    08-oct-2016
    Pamplona
    Leon 1m tdi 90cv ALH
    Agradecido 11 veces en 9 mensajes.
    Cita Iniciado por Alexilou Ver Mensaje
    Creo que tienes roto el remache de la palanca que sale del motorcillo. Esta, también es movida por la llave cuando lo abres manualmente.
    Quitando el plástico negro embellecedor podrás ver el fallo
    Enviado do meu ASUS_Z01KDA através do Tapatalk
    19-feb-2019
    Pamplona
    Cita Iniciado por MiGL Ver Mensaje
    Al final con la llave si lo puedo abrir, pero tengo que hacer bastante fuerza...
    Gracias por la respuesta
    Te esta fallando el sensor de temperatura del anticongelante situado en la caja de aguas (donde la tandem).
    Y lo otro tendrás que despanelar, ver el mecanismo. Quizas tengas roto el servo.
    Nº de Usuario: 19916
    03-may-2013
    alcala de henares
    lo del maletero puede ser que te falle un swing lleva dos uno en la maneta otro en la cerradura o falta de corriente
    Avatar de Chive
    Nº de Usuario: 19305
    29-mar-2013
    El Foro
    Alemanes
    Agradecido 61 veces en 53 mensajes.
    Gracias y saludos
    Que te lo solucione.
    19-feb-2019
    Pamplona
    Cita Iniciado por Chive Ver Mensaje
    Si si, ya está pedido presupuesto y aceptado por el vendedor
    Gracias a todos
