buenas
Al intentar casr las llaves de mi audi a4 b7 con super vag k+can plus 2.0 me ha salido en el cuadro LO 3-3 y ahora no arranca con ninguna llave.
intento borrarle los fallos , pero me vuelve a salir
Código:
VIN: WAUZZZ8EX6A032276 Mileage: 220140km/136788miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 910 401 K HW: 8E0 907 401 AJ
Component: 3.0L V6TDI G000SG 0030
Revision: --H01--- Serial number:
Coding: 0011111
Shop #: WSC 06325 000 00000
VCID: 2756F9C2A9B70224
1 Fault Found
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
RPM: 882 /min
Torque: 206.7 Nm
Speed: 0.0 km/h
Duty Cycle: 12.0 %
Voltage: 11.48 V
Bin. Bits: 00001100
Torque: 1035.3 Nm
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
Component: ESP8 quattro H04 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004425
Shop #: WSC 06435 000 00000
VCID: 2952FFFABFA33454
1 Fault Found
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0222
Hex Value: 0x0024
Hex Value: 0x018F
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AJ
Component: A4 Klimaautomat 2831
Coding: 00000
Shop #: WSC 00000
VCID: 69D2BFFA7F23F454
2 Faults Found
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
00474 - Control Module for Immobilizer
49-00 - No Communications
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0504
Coding: 01021
Shop #: WSC 00000
VCID: 3B7E35B2453FB6C4
1 Fault Found
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M005CVD6
Coding: 0034622
Shop #: WSC 06335 000 00000
No fault code found.
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0801
Coding: 02041
Shop #: WSC 06435
VCID: 4182475A27D3DC14
1 Fault Found
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 901 D HW: 8E0 920 901 D
Component: KOMBI+WFS 4 H12 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0004141
Shop #: WSC 03565 572 92637
VCID: 2648F4C6AEBD1B2C
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CA
Component: Komfortgerát T3B 3332
Coding: 07802
Shop #: WSC 06335
VCID: 72E0D89652F5378C
Part No: 8E1959801H
Component: Tõrsteuer.FS BRM 0406
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
3 Faults Found
00955 - Key 1
35-10 - - - Intermittent
00956 - Key 2
00933 - Electric Window Motor; Passenger Side (V148)
62-00 - No or Incorrect Adjustment
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 D
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000005
