Resultados 1 al 10 de 53
Tema: Poner faros bixenon vw caddy 2017
Ver Modo Hilado
  1. #23
    Nº de Usuario: 59356
    18-oct-2016
    Mundo
    Caddy outdoor 2.0TDI 150Cv
    no encuentro el modulo 55.
    pongo el autoscan completo por si te sirve
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    69-Trailer -- Status: Not registered 0001
    Address 01: Engine (J623-DFSB) Labels: 04L-907-309-V1.clb
    Part No SW: 04L 906 016 GN HW: 04L 907 309 K
    Component: R4 2,0L EDC H20 1668
    Revision: 8AH20---
    Coding: 01190032042415090000
    Shop #: WSC 35110 790 50316
    ASAM Dataset: EV_ECM20TDI01104L906016GN 001003
    ROD: EV_ECM20TDI01104L906016GJ_VN35.rod
    VCID: 7BF59D8AF2244A9AF5-802E
    2 Faults Found:
    17158 - Databus
    U1123 00 [032] - Received Error Message
    Intermittent - Not Confirmed - Tested Since Memory Clear
    17149 - Check Coding of ECUs on Powertrain Data Bus
    P1647 00 [032] - -
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels: Redir Fail!
    Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
    Component: ESC H06 0133
    Revision: 00000000 Serial number: 42546000001222
    Coding: 1079409BB367B47E0878027DCD8B2DD378F1F0
    ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
    ROD: EV_Brake1ESCCONTIVN75XGP2_VN35.rod
    VCID: 3F8D299AA6BC96BA99-806A
    1 Fault Found:
    0397 - TPMS Warning
    C102D F0 [008] - Pressure Loss
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 3
    Mileage: 23571 km
    Date: 2013.14.14
    Time: 18:54:21
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 1K8 907 044 CD HW: 1K8 907 044 CD
    Component: Climatronic H08 0405
    Revision: 00001K05
    Coding: 0510004003
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_ClimaAutoBasis_VW32.rod
    VCID: 73E5B5AADA7402DAAD-8026
    No fault code found.
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 AA HW: 5K0 937 086 AA
    Component: BCM PQ35 M+ 122 0184
    Revision: BD122001
    Coding: 671A0ABA8065086F08880080950089EC03DD0008426D8120E4 84C7000041
    Shop #: WSC 35110 377 08192
    VCID: 73E5B5AAD27402DAAD-8026
    Subsystem 1 - Part No: 2K1 955 119 D
    Component: Wischer 10091 26 0512
    Coding: 009795
    Subsystem 2 - Part No: 5K7 955 559 C
    Component: RLS 040916 04 42 0106
    Coding: 0228DD
    1 Fault Found:
    00931 - Locking Module for Central Locking; Rear Right (F223)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 76
    Mileage: 25443 km
    Time Indication: 0
    Date: 2014.14.11
    Time: 17:13:26
    Freeze Frame:
    Term 15 Off
    Voltage: 12.55 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
    Part No SW: 1K8 919 475 D HW: 5Q0 919 298
    Component: PARKHILFE PLA H12 0480
    Revision: -------- Serial number: 39431625002728
    Coding: 0031161141
    ASAM Dataset: EV_EPHVA2CVW364GP00 001010
    ROD: EV_EPHVA2CVW364GP00.rod
    VCID: 3B755D8AB2A48A9AB5-806E
    Address 13: Auto Dist. Reg (J428) Labels: None
    Part No SW: 7N0 907 572 C HW: 7N0 907 572
    Component: ACC Bosch PQx H03 0210
    Serial number: 14091604392284
    Coding: 00000000FE0339
    ASAM Dataset: EV_ACCBEGVW361 001006
    ROD: EV_ACCBEGVW361.rod
    VCID: 36634CBE898657F24A-8062
    Address 15: Airbags (J234) Labels: None
    Part No SW: 2K5 959 655 C HW: 2K5 959 655 C
    Component: VW10Airbag00G H08 0018
    Revision: -------- Serial number: 003V20012G6I
    Coding: 000000000000000000000000000000003047
    ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
    ROD: EV_AirbaVW10BPAVN750.rod
    VCID: 3C775E96B7AA8DA2BC-8068
    Crash sensor for side airbag: driver side:
    Serial number: 3497ARB404P42KLSC03M
    Crash sensor for side airbag: front passenger side:
    Serial number: 3507ARB404P42KLSHGUJ
    Crash sensor for side airbag: rear: driver side:
    Serial number: 3517ARB405342KLSFPCV
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 3527ARB405N44QG0911T
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 521 GE HW: 5K0 953 569 BF
    Component: LENKS.MODUL 018 0230
    Revision: FF010042 Serial number: 20160913200436
    Coding: 1082460008
    ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
    ROD: EV_SMLSNGVOLWSR8C.rod
    VCID: 75E18BB2D4001CEA83-8020
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 2K0 959 442 HW: 2K0 959 442
    Component: E221__MFL-TAT H06 0023
    Serial number: 2141600580900106BA1B
    Coding: 280000
    Address 17: Instruments (J285) Labels: None
    Part No SW: 2K5 920 876 F HW: 2K5 920 876 F
    Component: KOMBI H03 1104
    Serial number: 00000000000000
    Coding: 110A011200
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
    ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
    VCID: 387F42868392A18258-806C
    Address 19: CAN Gateway (J533) Labels: None
    Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
    Component: J533 Gateway H56 1682
    Revision: H56 Serial number: 180916F1000009
    Coding: 357430
    VCID: 7BF59D8AFA244A9AF5-802E
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 25991 km
    Time Indication: 0
    Date: 2014.14.21
    Time: 10:49:41
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 1104
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
    ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
    VCID: 6ADBA8CE8DBEC3121E-803E
    Address 42: Door Elect, Driver Labels: None
    Part No SW: 2K5 959 701 A HW: 2K5 959 701 A
    Component: Tuer-SG 009 2143
    Coding: 0136242
    VCID: 326B70AEADEE4BD266-8066
    Part No: 1K0 909 144 R
    Component: EPS_ZFLS Kl. 140 3501
    Revision: 00H22000
    VCID: 397947827098B88AA7-806C
    Address 4C: Tire Pressure II
    Cannot be reached
    Address 52: Door Elect, Pass. Labels: None
    Part No SW: 2K5 959 702 A HW: 2K5 959 702 A
    Coding: 0136242
    VCID: 336575AA52F442DA6D-8066
    Address 5F: Information Electr. (J794) Labels: None
    Part No SW: 5C0 035 680 D HW: 5C0 035 680 D
    Component: MU-S-N-ER H31 0359
    Serial number: VWZAZ2S5278067
    Coding: 06330701BE00000011110001000808001F0100D400200100CF
    ASAM Dataset: EV_MUStd4CTSAT 001022
    ROD: EV_MUStd4CTSAT_SK25.rod
    VCID: 224B80EE350EDB5296-8076
    Data medium:
    Subsystem 1 - Part No SW: 3G0 919 866 AQ HW: -----------
    Component: ECE1 2017 --- 0730
    Serial number: --------------------
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
    Component: Batt.regelung H56 1682
    Coding: 030F1873
    VCID: 71E9BFA2A86830CA5F-8024
    Subsystem 1 - Part No SW: 2K0 915 181 HW: 2K0 915 181
    Component: J367-BDMConti H03 1050
    Serial number: 75410603001609112755
    Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
    Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
    Component: Towbar module H09 0100
    Revision: 3A001001 Serial number: ÀÁ006789000000
    Coding: 0100000100000000
    VCID: 306F7AA663E279C210-8064
    End-------------------------(Elapsed Time: 02:59)--------------------------
    Última edición por Vredestein; 14/01/2018 a las 13:31
