CarlosApellido1 (14/12/2016), Osagui (17/12/2016), quitus (14/08/2015)
Under Seat Storage Tray DIY - Lot's of Pics
Installed on 2011 GTI 4 Door Autobahn.
Leather power recline seats with Dynaudio amp and Bluetooth module underneath the seats. So it should fit on any GTI.
Tools Needed:
T-20 Torx Bit
M-10 Triple Square Bit
Ratchet Wrench
Ratchet Extension Bar (~ 5-8 inches)
4mm Rivet Gun
Parts:
ECS Tuning includes all the hardware needed for install.
Parts by VW Number:
1x 1K0 882 601J 82V - Driver's Side Drawer
1x 1K0 882 602J 82V - Passenger's Side Drawer
1x 1K0 882 599B 9B9 - Driver's Side Guidance Frame
1x 1K0 882 600B 9B9 - Passenger's Side Guidance Frame
1x 1K0 881 547A - Driver's Side Retainer (Metal Piece)
1x 1K0 881 548A - Passenger's Side Retainer (Metal Piece)
4x N 900 978 02 - Pop Rivet 4x8x12.3
8x N909 998 01 - Oval Hexagon Socket Head Bolt M4x8.5 (T20 Torx)
Guidance Frames
Drawers
Step One:
Seats are held by 4 (2 Front 2 Back) Triple Square M10 bolts on the rails.
In a pinch, a T50 Torx bit will also work for these bolts.
Slide seat forward as far as it will go.
Remove the 2 bolts on the rear of the seats.
Step Two:
Slide the seat back as far as possible.
Remove the bolts in the front.
You can now gently tilt back the entire seat assembly.
You might want to move your seat back forward before doing this.
Also you will not need to disconnect any wires. Just be careful.
You remove the rear bolts first, because if you go front to back then the rails will shift when you slide the seat back with no bolts later.
Step Three:
Locate the rivet points underneath the seat.
Passenger's Side
Driver's Side
Line up the retainer metal piece and tape it in place if you have no one to hold it for you.
Use a rivet gun to attach the metal retainer piece.
Watch a Youtube video of how to use a rivet gun if you don't know how.
It's really easy.
Warning: The retainer pieces are side specific. Look at the pics carefully so you don't switch them. Once riveted, it will be a pain to fix.
Passenger's Side
Driver's Side
Step Four:
Place the guidance frames underneath the seat and line them up with the screw points.
It is easiest to screw them from outside in starting with the riveted brace.
The center screw will require you to go through the hole in the bottom of the tray. You will need to use the extension bar. This is also why you should not install the drawer into the tray until you are done.
Passenger's Side
Driver's Side
Step Five:
Take your drawer piece and line it with the guides in the frame.
Once the drawer meets some resistance, you can use a gentle tap to lock it into place.
You're done!
Additional Photos:
Thoughts:
-Installation is very simple and quick.
-Drawers add some much needed storage space.
-Drawers are lined with felt and match up perfectly with rest of interior.
-Leather was upholstered lower on my driver's side which prevents the drawer from closing properly. This is probably vehicle specific so YMMV.
-Drawers don't slide out very far. The pictures above are as far as they open.
ESTE MANUAL ESTA EXTRAIDO DEL FORO GOLFMK6.COM :
SE PUEDE COMPRAR TAMBIEN MAS GRANDE PARA TIGUAN , GOLF PLUS , PASSAT , Y OTROS MODELOS SIEMPRE ELIGIENDO SI ES ASIENTO DE CONDUCTOR O ACOMPAÑANTE ,
Y EL COLOR ADECUADO A TU INTERIOR EN LOS SIGUIENTES SITIOS:
Última edición por jevi007; 14/08/2015 a las 15:07
Osagui (17/12/2016)
INSTALACION PARA GOLF V
DIY - Seat Drawer Install
Tools Required:
- 10mm Triple Square Socket (can be found on ZDMAK.com)
- Rivet Gun
- T-20 Torx
- Cordless Screwdriver with ability to attached torx bit with extension (recommended)
Parts Required:
- Seat Drawer Kit
- 5 pcs. T-20 Torx screws (included with kit)
- Bracket (included with kit)
- 2 pcs. pop rivet
Install Time:
30-45 minutes
Última edición por jevi007; 14/08/2015 a las 14:50
Cajones bajo asiento del EOS para Passat 3C:
Izquierdo:
1K0 882 601 E 82V cajón negro titanio 22,95 EUR
N 909 998 01 torn.alomado hex.interior red. 0,09 EUR
6Q0 881 203 pieza deslizante 0,39 EUR
6Q0 882 331 tope elástico 0,50 EUR
1K0 882 599 B 9B9 bastidor guía negro satinado 10,00 EUR
1K0 881 547 A soporte 1,85 EUR
N 900 978 02 remache ciego 0,28 EUR
Derecho:
1K0 882 602 E 82V cajón negro titanio 22,95 EUR
1K0 882 600 B 9B9 bastidor guía negro satinado 10,00 EUR
1K0 881 548 A soporte 1,85 EUR
Suma todo y añádele el 31%
Mem
Osagui (17/12/2016)
IMAGEN DE CAJON ALMACENAMIENTO GOLF PLUS
Interesante, antes los cajones eran tipo "armario", sin embargo veo que estos se abren con las guías y vienen acolchados.
Buen tutorial, lo anoto porque he visto que a los skodas tambien se le puede poner y supongo que sera muy parecido
jevi007 (21/09/2015)
Muchas Gracias
Muy, pero que muy interesante. Anotado en recámara. Gracias
Gracias al foro: Espejos abatibles con mando, lunas un solo toque, coming home automático, DRL sólo con mando en "auto" y sin freno de mano, luces de seguridad en puertas, corriente en puertas sin contacto, desacivación pantallazo start/stop en fis, limpialágrima, pedales y reposapiés R-Line, RNS 510 (actualizando fw y mapas), cámara trasera logo, instalación alarma, cambio luz matrícula a led...
muy buen brico.
yo lo pedi de serie cuando me compre el coche, y le doy bastante uso, aparte que es un hueco que aprovechas y sino se sabe ni se ve..
