Wednesday,01,April,2009,16:03:59:26365
VCDS Version: Beta 812.4
Data version: 20090214
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 HW: 1K0 907 115
Component: 2.0l R4/4V TFSI G00 0070
Revision: --H01--- Serial number: VWZ7Z0E2037855
Coding: 0403000318070160
Shop #: WSC 00267 572 71897
1 Fault Found
005634 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0000
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 290010541908A7
Coding: 7D0F0342070000
Shop #: WSC 01279 785 00200
1 Fault Found
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 14
Reset counter: 162
Mileage: 76763 km
Time Indication: 0
Date: 2000.00.00
Time: 17:54:30
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AQ HW: 1K0 959 433 AQ
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 009002085103087F2D04840420084A01E0A440
Shop #: WSC 00000 785 00200
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 162
Mileage: 0 km
Time Indication: 0
