Resultados 1 al 5 de 5
Tema: AUTOSCAN - Primer Autoscan (Dudas-Fallos)
    Nº de Usuario: 19
    30-jun-2008
    Na volta do vento
    Bertolini
    Predeterminado AUTOSCAN - Primer Autoscan (Dudas-Fallos)
    Bueno antes de nada gracias a pablo por su paciencia, a la hora de ayudarme a configurar el cable.
    A ver si veis alguna cosa rara, yo por el momento los he borrado todos. Son todos intermitentes.
    Wednesday,01,April,2009,16:03:59:26365
    VCDS Version: Beta 812.4
    Data version: 20090214
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 1K0 907 115 HW: 1K0 907 115
    Component: 2.0l R4/4V TFSI G00 0070
    Revision: --H01--- Serial number: VWZ7Z0E2037855
    Coding: 0403000318070160
    Shop #: WSC 00267 572 71897
    1 Fault Found
    005634 - Power Supply Terminal 30: Voltage too Low
    P1602 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: -40.0°C
    Absolute Pres.: 0.0 mbar
    Voltage: 0.000 V
    Readiness: 0000 0000
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 E HW: 1K0 907 951
    Component: Gateway H11 0110
    Revision: 11 Serial number: 290010541908A7
    Coding: 7D0F0342070000
    Shop #: WSC 01279 785 00200
    1 Fault Found
    01331 - Door Control Module; Driver Side (J386)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 14
    Reset counter: 162
    Mileage: 76763 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:54:30
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 AQ HW: 1K0 959 433 AQ
    Component: 01 KSG PQ35 G2 010 0101
    Revision: 00010000 Serial number: 00000000000000
    Coding: 009002085103087F2D04840420084A01E0A440
    Shop #: WSC 00000 785 00200
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    1 Fault Found
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 162
    Mileage: 0 km
    Time Indication: 0
    Última edición por Josinho; 16/02/2010 a las 21:29
    Avatar de jurjito
    Nº de Usuario: 20
    30-jun-2008
    Passat 3C 2.0 TDI 140cv(BKP) DSG(HXS)
    Agradecido 107 veces en 53 mensajes.
    Pues a ver, hay dos errores principales.
    El primero es de voltaje demasiado bajo, que puede ser porque se haya descargado la bateria antes de que lo compraras, aunque es raro que solo salga en el modulo del motor.
    El otro es un error de comuncación con el modulo de la puerta del copiloto, y se ha repetido bastantes veces.
    Lo mejor es que borres ambos y compruebes dentro de una semana si se han repetido. Si no se han repetido, vuelvelo a comprobar pero dejando algo mas de tiempo...
    Salu2
    MI PASSATXU ^^
    Avatar de barri_rock
    Nº de Usuario: 2673
    21-nov-2009
    SALAMANCA
    VW JETTA 2.0 TDI BI DSG 140CV
    Todo puede venir de cuando te han reparado el golpe de la carretilla. La puerta, porque la hayan desconectado y la batería quizá se descargara en la sección de chapa (muy común, no sé porque).
    Yo no le daría más importancia, vuelve a chequearlo en unos días a ver si te las vuelve a dar.
    Un saludo!!
    JETTA 2.O TDI BI DSG 140CV
    OCTAVIA 1.9 TDI BXE
    by ELECTROCHIPS SALAMANCA
    Avatar de jurjito
    Nº de Usuario: 20
    30-jun-2008
    Cita Iniciado por barri_rock Ver Mensaje
    Un saludo!!
    Cierto, es verdad, pensaba que era la puerta del copiloto, pero ahora que me he vuelto a fijar es la del conductor, asi que si, seguramente sea de cuando se la han reparado...
    Salu2
    MI PASSATXU ^^
    Nº de Usuario: 19
    30-jun-2008
    Na volta do vento
    Bertolini
    Muchas gracias .Estaré atento de todas maneras a esos fallos.. jeje
