hola a todos haber si me podeis orientar un poko con el vag com le e echo un log a mi cordoba este a sido el resultado
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 038 906 019 KT
Component: 1,9l R4 EDC 0000SG 5213
Coding: 00102
Shop #: WSC 06441
VSSZZZ6LZ4R026171 SEZ7Z0C2128187
No fault code found.
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 G
Component: ABS 5.7 FRONT V30
Coding: 00044
Shop #: WSC 06441
Address 08 -------------------------------------------------------
Controller: 6L0 820 045
Component: Klimaanlage X0840
5 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to B+ - Intermittent
01271 - Positioning Motor for Temperature Flap (V6
![](http://www.vagclub.com/forum/images/smilies/icon_cool.gif)
28-10 - Short to B+ - Intermittent
29-10 - Short to Ground - Intermittent
00819 - High Pressure Sensor (G65)
07-00 - Signal to Low
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 00012
Shop #: WSC 06441
2 Faults Found:
00906 - Horn (H1)
01598 - Drive Battery Voltage
07-10 - Signal to Low - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 801 A
Component: KOMBI+WEGFAHRSP VDO V10
Coding: 00144
Shop #: WSC 03366
3 Faults Found:
00779 - Outside Air Temp Sensor (G17)
01128 - Immobilizer Pickup Coil (D2)
35-10 - - - Intermittent
01176 - Key
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 65 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06441
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 R
Component: LenkhilfeKYO V913
Coding: 10111
Shop #: WSC 06441
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 03 Komfortgerát 0002
Coding: 00066
Shop #: WSC 06441
End -------------------------------------------------------
ke tal lo beis y si me podeis decir de que son los fallos y como solucionarlos
![](images/smilies/icon_smile.gif)
