Enhorabuena !!! 0 averías, a disfrutar de ese coche. salu2
bueno gente
me demoré un poco pero aqui esta el scan a ver que os parece
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 056 AA HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 2898
Revision: --H09--- Serial number: SEX7Z0I231A0BW
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 66C9A841517CEC9
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B2012092700FC881204EA901E00413400
Shop #: WSC 04941 231 15432
VCID: 74EDC209D7A00E9
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
VCID: 2D5B176DB40A1F1
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000006053985
Coding: A1880FAF0004100F431D00002D00000000017F075C40000C00 0000000000
Shop #: WSC 43256 213 42544
VCID: 336F0115522E491
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 170209 022 0601
Coding: 00056208
Shop #: WSC 43256
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A01 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP4BBG9F
Coding: 0012337
Shop #: WSC 06402 785 00200
VCID: 3B7F29357A7E811
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 855 0111
Coding: 0000134
VCID: 7AF1EC3135C4789
Part No: XXXXXXXXXXX
Component: E0221 001 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 840 C
Component: KOMBIINSTRUMENT VO3 0522
Coding: 0002101
Shop #: WSC 00599 843 01477
VCID: 2B5F19758A1E111
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K0921600D3
Coding: E9807F06000202000202
VCID: 377735054656A51
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0522
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1517
Revision: 71009005 Serial number: 00000759389119
Coding: 0004272
VCID: 40855ED91398E29
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.065 H08 1901
VCID: 356B3F0D5C5A571
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 988008005283CC7F00068F0F60084F86107C80
VCID: 830F11D5C20EB91
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 43256
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1517
Revision: 71009005 Serial number: 00000500789128
Coding: 0004272
VCID: 41835BDD1892EB1
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0007
Coding: 0040424
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000003810852
Coding: 0000144
VCID: 74EDC20917A00E9
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000003806659
Coding: 0000144
VCID: 75EBFF0D1CDA171
sograndio (25/05/2013)
hola como fue que lo codificaste yo tengo exactamente el mismo problema le agradeceria mucho me dijera como lo soluciono y lo codifico? muchas gracias saludos
como fue que lo codificaste? yo igualmente tengo el mismo problema me aparece en puros ceros el coding.. muchas gracias agradeceria mucho me dijeras como lo hiciste con tu vagcom, buena noche
no lo tengo y me pasa exactamente lo mismo no tengo el codigo, esto me paso a raiz de haber cambiando los NIV de la ecu y del cluster, cuando volví a montar ecu y cluster me desconfiguro el abs me aprece abs no codificado y parpadea el testigo de abs y ctl de traccion en conjunto, y quisiera saber el precedimiento para codificarlo. el codig que te proporcionaron arriba de 36 caracteres no te funcionó? muchas gracias quedo atento a su respuesta
me arroja 2 faults:
01042-Control Module; Not coded
000--
00778-Steering Angle Sensor (G85)
005-No or Incorrect Basic Setting / Adaptation.
El segundo estoy seguro que lo arroja por consecuencia del modulo ABS no codificado
Dsiculpen, asi es tienes toda la razón, lo que pasa es que ya llevo mucho tiempo con el problema y cuando lei tu post de verdad que me abriste una nueva esperanza, una disculpa nuevamente,
