1º Marca, modelo, caballos, año de compra y código de motor del coche afectado.
2º Qué es para ti: "quitar la protección de componentes"
3º Probaste a borrar esas averías??
hola a todos , despues de kitar la proteccion de componentes ... me encuentro con estos errores
Address 13: Auto Dist. Reg Labels: None
Control Module Part Number: 5Q0 907 572 A HW: 5Q0 907 572 A
Component and/or Version: ACC Bosch MQB H03 0141
Software Coding: 00000400FE0339
Work Shop Code: WSC 03677 002 104857
ASAM Dataset: EV_ACCMRRBoschVW372 001013 (SE37)
VCID: 3561C75F94B4ADB6775-8060
4 Faults Found:
1058 - Databus
U1123 00 [009] - Received Error Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 13759 km
Date: 2015.02.17
Time: 21:35:33
1039 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 13759 km
Date: 2015.02.17
Time: 21:35:33
0111 - Dynamometer Mode Detected
C10A7 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 29
Mileage: 13759 km
Date: 2015.02.17
Time: 21:36:54
1807 - Function restriction
C10C2 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 29
Mileage: 13759 km
Date: 2015.02.17
Time: 21:35:33
Tuesday,17,February,2015,21:49:18:62939
VCDS Version: Release 12.12.0
Address 01: Engine Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 021 M HW: 04L 907 309 B
Component and/or Version: R4 1,6L EDC H22 6545
Software Coding: 01110012036401090000
Work Shop Code: WSC 00049 770 00125
ASAM Dataset: EV_ECM16TDI01104L906021M 002011 (SE37)
VCID: 2F6DF53776E897663D9-807A
2 Faults Found:
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 13759 km
Date: 2015.02.17
Time: 21:46:33
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 13759 km
Date: 2015.02.17
Time: 21:46:32
Readiness: 0 0 0 0 1
me podeis ayudar a interpretarlos? cual seria la solucion??
lo que se es que tengo que cambiar los sensores de ABS , con lo cual alguno de estos errores indique este fallo
gracias de antemano
demonjrm (18/02/2015)
1 - seat leon ,1.6 tdi , 105cv , style , 2014 , CLHA , manual
2 - quitar componentes para mi es llevar el coche al conce para que , por mediacion del VAS conectado online , asigne el chasis de mi coche a un modulo de control con otro chasis asignado ( en este caso el radar ) , despues de comprobar que no esta en la lista de robos .
si , he intentado borrar averias .
No se como interpretar las averias que tengo , pero seguro que desaparece alguna cuando instale los sensores de ABS apropiados para este sistema , ya los tengo , a ver si saco un rato para hacerlo .
gracias por responder
estoy un poco perdido con estas averias porque he intentado buscar de que son en ross tech pero no he encontrado nada ...
Última edición por demonjrm; 18/02/2015 a las 19:31
Las averías, cómo bien sabes, las da en el módulo de regulación automática de distancia, y sinceramente, no se a que se refieren dichas averías, es la primera vez que las veo. Quizás sea lo que tú has comentado, que con poner los sensores de ABS apropiados para ese sistema este problema se resuelva (no lo sé) pero así te lo deseo.
También te marca avería de que revises los coding (o el coding) de las centralitas (o centralita) y que no hay comunicación entre la maneta del control de crucero (Tempomat) con el sensor de distancia. Seguramente esta última avería tenga que ver con las averías del módulo de regulación automática de distancia. Si todo esto a aparecido tras pasar por el concesionario, yo llevaba el coche a ver que me dicen, o esto haría yo. Salu2
gracias por tu ayuda ... voy a ver las averias que se quedan cuando ponga los sensores abs y a partir de ahi veo como las voy solucionando
de todas formas tengo 4 averias ... si alguien sabe cuales son ( aparte de la que me ha comentado el compañero codi31 de la comunicacion de la maneta del tempomat con el modulo de radar .... ) , por mas que busco informacion sobre ellas ... no encuentro esos codigos de error
saludos
Tú modelo de coche, es relativamente nuevo, no vas a encontrar apenas información de los códigos de avería que te muestra porque ni siquiera en Internet ni en ningún foro aún se han manifestado, y si se han manifestado, en un modelo del 2014 (como es tu caso) ese coche aún esta en garantía, y no se han complicado y lo han llevado al concesionario, no se han molestado en pedir ayuda en un foro.
Yo he intentado buscar información, y lo único que he encontrado a sido esto:
Al parecer, esta persona también realizo una actualización o cambio, y le apareció este código de avería:
Si tú sufres estos problemas a raíz de quitar la protección de componentes en concesionario, lleva el coche y que te den una explicación, porque ellos fueron quienes estuvieron trasteando. Ese coche tendrá garantía, no?? esto haría yo, pero si quieres esperar mas ayuda en el foro, estas en tu derecho, te deseo suerte.
muchas gracias ,
evidentemente si estos errores me los da algun componente del coche estando de garantia , lo llevo al conce ... pero cuando instalas el Adaptative cruise control (ACC), desarmas todo el volante con toda la electronica y demas ... naturalmente no cubre eso la garantia , al contrario , me arriesgo a perderla . Asiq solo me he limitado a llevarlo para que me quiten el CP para poder codificarlo .
un saludo y gracias nuevamente por buscarme informacion sobre las averias
ya he solucionado uno de ellos , tonto de mi no habia codificado el modulo 16 , para pasar de control cruise a adaptative cruise control de 2C00 a 6C00
graciaas nuevamente , a ver si mañana tengo un momento y pongo los sensores ABS
