Llevas kit de xenon?
hola a todos. necesito que me ayudéis, me han salido estos errores en el passat y a ver si me podéis echar una mano de que puede ser esos errores...
gracias.
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Sunday,28,January,2018,12:04:25:62939
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
Mileage: 154370km/95921miles
01-Engine -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BL HW: 03L 907 309
Component: R4 2.0l TDI 0001SG 9977
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00637 572 175557
VCID: 70EF364B6356C89E643-8025
1 Fault Found:
001027 - EGR Valve (N18)
P0403 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 153885 km
Time Indication: 0
Date: 2000.00.00
Time: 16:32:57
Freeze Frame:
RPM: 1748 /min
Speed: 60.0 km/h
Load: 35.7 %
Load: 14.9 %
Lambda: 100.2 %
Mass Air / Rev.: 550.0 mg/str
Temperature: 85.5°C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000785222479
Coding: 0000267
Shop #: WSC 05311 000 00000
VCID: 1F4D05F7CE4807E68D9-804A
No fault code found.
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CR HW: 3C0 907 044 CR
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 73E539471240F386991-8026
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007977222
Coding: 01800F0700041A00470A00000F00000000095D435C00010000 0000000000
Shop #: WSC 05124 000 00000
VCID: 71E9334F685CC1966BD-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 290108 003 0205
Coding: 00046997
Shop #: WSC 05124
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__005 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP34DAC6
Coding: 0012341
VCID: 3B75D1677A907BC6811-806E
Subsystem 1 - Serial number: 6333FTS615740388
Subsystem 2 - Serial number: 6343FTS664720368
Subsystem 3 - Serial number: 6353ETS6Q3MGSVNP
Subsystem 4 - Serial number: 6363ETS60PUGSVNH
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AB HW: 3C0 953 549 AB
Component: J0527 0020
Revision: 00026000 Serial number: 3C5953507AM
Coding: 0000003
VCID: 6CD7223B4F7E2C7E58B-8039
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 860 N HW: 3C0 920 860 N
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 78654 326 999999
VCID: 2D51EF3FB4E4E5760F5-8078
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P0822003B7
Coding: F9807F060002021002
VCID: 23450907E2202306A91-8076
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 3979CB6F70AC49D693D-806C
Subsystem 1 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1131
Revision: 32008001 Serial number: 00000637088218
Coding: 0000181
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.134 H08 1901
Shop #: WSC 02069 000 90108
VCID: 3561C75F5CB4ADB6775-8060
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 00910A0001860E763004941570084F0B607CA1
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000543288215
Coding: 0000180
VCID: 3C77D27B7F9E7CFE88B-8069
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000362970
Coding: 0000057
VCID: 29591B2F800CF956E3D-807C
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 AD
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2H6059682
Coding: 0040400
Shop #: WSC 05314 000 00000
VCID: 68DF5E2B5B86005E3C3-803D
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0308
Revision: 41004101 Serial number: 00000000227893
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0308
Revision: 41004101 Serial number: 00000000247648
Coding: 0000144
posiblemente tengas que cambiar la egr. se te enciende la luz amarilla? ha sido un fallo intermitente, puede que borrandolo se acabe el tema, o te vuelva a salir dentro de un tiempo.
hace 1 semana se me puso el coche en limp mode, no pasaba de 100 y se encendió el testigo de los calentadores, aparque el coche 5 min y lo volví arrancar y se quito el chivato de los calentadores y el coche va bien... pero al pasar el vagcom he visto eso y no se si la avería puede ser por la EGR.
gracias.
Te pego la descripción de tu avería sacada de la página Oficial de Ross-Tech:
16787 - Válvula de re-circulación de gases de escape (EGR) (N18): mal funcionamiento.
Posibles síntomas:
- Testigo de avería encendido en el cuadro (MIL ON).
- Perdida de potencia (Limp-Mode).
Posibles causas:
- Fusible (s) defectuoso.
- Cableado/conector de la válvula de re-circulación de gases de escape (EGR) defectuoso.
- Válvula de re-circulación de gases de escape (EGR) (N18) atascada / defectuosa.
Posibles soluciones:
- Verificar fusible (s)
- Verifique el cableado/conector de la válvula de re-circulación de gases de escape (EGR)
- Comprobar/reemplazar la válvula de re-circulación de gases de escape (EGR)
- Verifique los valores de EGR en el bloque de medidas del motor (Vag-Com).
End................. ................................. ...........................................
En tu modelo la EGR es eléctrica, no lleva válvula N18. Por tanto, verifica los fusibles del coche uno a uno, sacando cada uno de su emplazamiento (no los compruebes con ellos puestos) usa un tester o polímetro, no los mires a ojo. Que están todos bien? siguiente paso.
Comprueba el cableado/conector de la EGR. Mira los pines de los conectores, por si hay alguno doblado o sulfatado, que los cables estén bien y no pelados, intenta medir continuidad (etc..) y si esto está correcto, mira con Vag-Com si la EGR trabaja bien, y si no, pues toca cambiarla.
También deberías comprobar, si la mariposa de la EGR se abre/cierra al apagar el motor.
Última edición por codi31; 29/01/2018 a las 15:12
En el modelo BKP hay dos tipos de EGR, las de toda la vida pneumaticas y electricas.
Basta con ver la EGR si le llega un manguito de vacio pues si lleva N18. Si no le llega ningun manguito de vacio pues es eléctrica.
ese coche es common rail (fijaos en los labels del modulo engine), y dudo que tenga mal el cableado, pecan de egr esos motores (me apuesto que es un 2.0 tdi 140 cr)
Última edición por CarlosApellido1; 30/01/2018 a las 00:35
Whitsnak (31/01/2018)
CarlosApellido1 (31/01/2018)
